MS3-v3( CAM CARD) SPECKS
MS3-v3( CAM CARD) SPECKS NEEDED
Search is not working.Can someone post a copy of the cam card specifications,i called TSP on tuesday and they were supposed to fax them too me. im planning on degreeing it in and would like to have them handy THANKS!!!!
you need to have them fax a copy of your cam specs. should have a serial number or have it cam doctored. each cam will be slightly different. for instance, my f14 is supposed to be .598/.598 but is actually .599/.600 so. Now, the durations and lsa's should check out. also it should have any advance scribed on it too. (i know you know that but just saying, ex: 112+2 etc.) I hope that helps. if not, just keep doing a search and it should come up.
Ski
Specs are 237/242 .603/.609" LSA 113
Ski
As mentionned,most cam grinds are different.
To degree yours you have to make sure you have YOUR cam card.
If they do not have that particular one, only way to do it correctly would be to cam doctor it and then use that data.
But with a serial number, TSP can get one from Comp (I would think so anyways)
