Another Head Gasket ?
Old 12-22-2006, 12:08 PM
TLKSCHP's Avatar
Default Another Head Gasket ?
Turns out no one local has any. My plan was to go get the GM MLS ones but I guess it is listed for 02 and up. I have a 98, can i not use them? i found some Fel pros but anything else has to be ordered.
Recommendations anyone?
Not planning anything special like boost or a 150 shot, to poor and chicken for the other. 11's N/A is fine for me.
Old 01-03-2007, 02:42 AM
kawasakiklx's Avatar
Old 01-03-2007, 07:07 AM
Mssingkid's Avatar
Well are you changing the heads??? If not the 98 heads have a notch in them that requires a gasket for only 98 models. If you don't use 98 gaskets for 98 heads YOU WILL HAVE A LEAK! If your moving up to say 243's, then you can use what ever gasket you'd like.
