Does a 6.0 lq4 have a different harmonic balencer than ls1?
Old 12-23-2006, 12:46 AM
Has Unresolved Sales In Feedback/12 second club
notatruews6's Avatar
Default Does a 6.0 lq4 have a different harmonic balencer than ls1?
I have a 6.0 lq4 in my 99 Trans am, I am geting a wierd vibration coming fromt the motor, i rembember my engine builder telling me that he used the stock ls1 balancer instead of the damaged 6.0 one? My question is are they different?
Old 12-23-2006, 07:22 AM
jay_lt4's Avatar
all the stock 4.8, 5.3, 5.7 ls1, 6.0;s are internally balanced, the crank pulley doesnt even have a keyway so it can go on in any position and you should be fine, it is a crank pulley/dampner and has nothing to do with engine balance
Old 12-23-2006, 11:43 AM
Grimes's Avatar
I think the offset for the belts are different depending on vehicle. For example, the vette balancer is different from fbod.
Old 12-24-2006, 02:50 AM
PREDATOR-Z's Avatar
I do not want to raise bells but you mentionned "damaged" balancer and the " vibrations"
Was the crank checket for any damage, or bearing dammage before re-install?
It is possible those are crank vibrations, I would get the crank pullet stobe lit to read any wobbliness, to see if it is pulley or crank related.
Old 12-24-2006, 10:36 AM
black_z's Avatar
IF the pulley was damaged, there is a good chance the crank was also damaged.
Old 12-24-2006, 12:16 PM
Quik's Avatar
a truck accesory is different then a fbody one. you will need to use a car one on a 6.0
Old 12-24-2006, 12:49 PM
PREDATOR-Z's Avatar
You use the peripherals from the car it is in.
Old 12-30-2006, 11:50 AM
Update: the 6.0 balancer that was damaged was just the rubber peice, it was coming out. ive had the crankshaft checked when i had the motor out.
Old 12-30-2006, 05:42 PM
Grimes's Avatar
Good catch, hope things work out now!
Quick Reply: Does a 6.0 lq4 have a different harmonic balencer than ls1?
