G5X3 plus SLP 1.85 rockers....Problems?
Hey guys, I was pondering the idea of adding a set of SLP 1.85 rockers to my current G5X3 cam to get a more LSK'ish lift out of it...
My current springs are ETP "PSI" springs rated to .650 lift. My current head setup consists of ETP 215 at 59cc with .040 gaskets. Clearances are: .140 intake/.225 exhaust.
Will I have a problem with PTV or will this be ok?
Any opinions if this is a good idea?
TIA!
TIA!
Any other options on getting more lift out of the cam? Do we have a 1.8 rocker arm available to us?
Thanks for the comments Louis...How do you think this would compliment the setup? Do you see it being mediocre or a noticable improvement? Any thought to what other tuners are doing with their cam profiles and the LSK lobes?
TIA!
TIA!
Give me a rundown of the entire package, bolt ons and what not and we can go from there.
As I sit here, I think of what I can test it on. I knew I was crazy, I just forgot
https://ls1tech.com/forums/showthrea...hlight=etp+ls7
Read that thread. When we swapped heads, I swapped rockers so that the LS7 side was not getting a benefit from the added lift/duration of the 1.8 over the 1.7
Let me know if I can help
Louis
Louis
Vararam/Halltech airbridge/Ported Fast 90/ported LS2
LG LT's pro offroad/B&B PRT's
ETP 215 at 59cc/.040 Cometic/G5X3-114
Meziere EWP
I'll give the link a read....I was just curious of the increase in lift and how it would effect the valvetrain and power....
TIA
Meziere EWP
TIA
