heads/cam decided...?
Old 12-28-2006, 02:12 AM
LineLocked&Loaded's Avatar
Default heads/cam decided...?
I think i've made my final decision for a head/cam package for my 02 LS1/a4...going to be a daily driver 2
(everything from TSP)
-stage 1 ls6 heads w/prc dual spring kit
-233/239 114lsa cam
-ls6 ported oil pump
-ls2 timing chain
-heads/cam bolt gasket kit
...damn...trying to search for the right h/c package on a tight budget is a big bitch...huh.
all the searching/thinking gave me a fu*kin headace...
to everybody with this combo (or similar to this), make me feel better and tell me this is a good setup...
or heck...anybody 2nd this setup would be helpful too.
Old 12-28-2006, 03:33 AM
PREDATOR-Z's Avatar
What is your stall?
Old 12-28-2006, 08:45 AM
Dr. Jeckel's Avatar
Originally Posted by PREDATOR-Z
What is your stall?
Along with this very important question, you might think about the PRC 5.3L stage 2.5 heads. They will increase your compression a bit for better midrange and are actually like $100 cheaper than the LS6 stage 1's.
Old 12-28-2006, 01:04 PM
have no stall yet...suggestions?
Old 12-28-2006, 01:06 PM
wouldn't I have to flycut...?
Old 12-28-2006, 02:10 PM
HAMRHEAD's Avatar
You can look at a 3800 stall
Old 12-28-2006, 02:21 PM
Dr. Jeckel's Avatar
Nope, I just got through reading it in a post from Zach at TSP (I believe) on the subject.
I had a Yank ST3500 in my TA and loved it. It made to much torque for DR's and e.t. streets barely held the torque with my setup.
Old 12-28-2006, 02:28 PM
Ericbigmac83's Avatar
im pretty sure there are some people on here with that setup, ill try to remember who. i talked with one cause thats the setup i want also, just undecided on the heads...so the 5.3's will work
Old 12-28-2006, 03:02 PM
yeah...the stage 1 LS6 or the stage 2.5 heads is my toughest decision. either one would be good to me and price diff. is not that bad also.
both shouldn't have any clearance issues with 233/239 cam.
Any big deal between the two..? as far as power?
Old 12-28-2006, 04:29 PM
Dr. Jeckel's Avatar
the 5.3's will up your compression to 10.75:1, but as far I can gather they flow similarly with the intake runners of the 5.3's being 220 and the LS6's being 237.
I believe the LS6's would work better for bigger cams and better top-end performance and the 5.3's would be better for middle sized cams.
I think the difference would be seen in side by side comparisons of the HP and TQ curves, not necessarily in peak numbers.
There is no testing to back any of this up, just speculation on my part.
Old 12-28-2006, 04:31 PM
good stuff...thanks
Old 12-28-2006, 04:42 PM
TSP must be busy...can't really get a hold of them.
anyone know when their heads/cam sale going to end?
Old 12-28-2006, 05:57 PM
white_camaro's Avatar
let me know what you get because im in the same situation. i allready have the 233/239 114 cam and am looking at heads next. i also allready have a 3800 stall and it works well with this cam. im up in the air about which heads to get, the 5.3's or the ls6's. which heads would work better for a more track oriented set-up, i hardly do any street racing? what about milling, valves, and gasket size?
Old 12-28-2006, 07:16 PM
i'll try give them a call again tomorrow..
Old 12-28-2006, 11:26 PM
let me know if you hear from them...
Old 12-29-2006, 02:28 PM
I finally got a hold of them today and spoke w/jon@tsp...(they must be swamped). I went with the 5.3L heads/cam package instead..which is still good...but as far as putting them on...It should be a straight forward setup, just gotta take your time and be careful...like with any other mod...
...did anyone have any problems with the setup?
Old 12-29-2006, 05:05 PM
JRracing's Avatar
This sounds like a really good set up. I bet it will make great power. And it will fly with a good stall. I've been watching results on this cam.
I'm in the market for H/C as well. It gets really tough when choosing one. So many options and great products out there!
Old 12-29-2006, 05:12 PM
yeah, I know...tell me about it
