Deck Height Question
Old 12-28-2006, 11:58 PM
14 Second Truck Club
Hemi Killer's Avatar
Default Deck Height Question
My machine shop told me they decked the block "10 out of the hole". What's my deck height? Motor details in sig.
Old 12-29-2006, 01:29 AM
LS1 Swapper's Avatar
0.010" above the deck, the pistons are going to come out of the block that much. I think that is what your asking.
Old 12-29-2006, 02:20 AM
So, if I'm running a F13, patriot heads milled .003-5", and deck height of .010", will 7.400" pushrods be okay? What is the stock deck height of an 98' LS1? Thanks
Old 12-29-2006, 02:32 AM
Asmodeus's Avatar
stock pistons are .007 out of the hole if that's what you're asking.
I'm not sure what lobes Futral is using atm, still Cam Motion?? Anyways, I don't know how much if any smaller the base circle is on a F13 over a stock lobe so I can't calculate exactly the length you need.
you're shorter by about .010 not factoring in a smaller base circle (possible, and would make a perfect pushrod a tad longer) and PR's usually vary in .025 increments unless custom.. I would guess 7.400 would be the closest.
Old 12-29-2006, 08:45 AM
Alright, thanks!
