stock LS6 heads vs Ported LS6 heads
Old 12-29-2006, 10:51 AM
2fastWS6's Avatar
Default stock LS6 heads vs Ported LS6 heads
OK guys I need your help deciding.I want to build a strong street car not a 1/4 mile race car with good low and mid range pull.I have the LT headers and SLP lid.I want to get a cam and heads.I need help deciding on which heads to get.I saw that Patriot has the special on the stock 243 bare for 350,stock valves for 20 and the gold spring kit for 220 I think it was.This sounds good to me.What is your thoughts.Is there anyone running the stock 243,cam,Lt and air lid.Would like to here from you.What is the difference between the ported and none ported as far as hp and torq.curve goes.I think the stock 243's would make a better street head because of the smaller runners IMO.I would like to target the 425 rwhp range is this posible?
Thanks
Old 12-29-2006, 05:06 PM
BROKEN's Avatar
i say you see 15 rwhp diff from non ported to ported for more power go for the ported...as far as horspower what are you cam specs you picked out
Old 12-29-2006, 05:10 PM
ws6togo's Avatar
Im running stock 243's....wish I would have ported them. But as you can see in the sig the car is plenty strong for the street.
Old 12-29-2006, 06:19 PM
98RedZone's Avatar
Do you have torque numbers or a graph? Also, any specs on your cam? I too am very tempted by the Patriot special going on.
Old 12-29-2006, 06:34 PM
Irocss85's Avatar
Id like to see your graph too. what kind of dyno was that on? mustang dyno? your time slip looks almost identical to mine. see sig. have yet to dyno mine though. also curious about your cam and what tires you using? full weight?
Old 12-29-2006, 09:32 PM
2fastWS6's Avatar
ws6togo that is very impressive times.I would be very happy with that for a street car.
that is what i am lookig for.Tell me more.what are your cam specs.You must be running some kind of drag slick right?
Old 12-29-2006, 11:23 PM
eamador11's Avatar
Cartek 2x ls6 heads
Old 12-29-2006, 11:41 PM
1999ssls1's Avatar
go ported
Old 12-29-2006, 11:44 PM
cantdrv65's Avatar
Post
Don't buy all that small runner bullshit.... I went from the stock Ls6 heads on my Z06 to the TSP ported 243's. I picked up power in every part of the rpm band. went from 410rwhp to 435rwhp with no other additions besides the heads. Then added 15rwhp with a Fast 90/90 to get 450rwhp....
Old 12-30-2006, 12:03 AM
2fastWS6's Avatar
thanks thats encouraging news.what cam are you running?
Old 12-30-2006, 01:59 AM
SunsetHawk's Avatar
Is patriot still doing there special?? I can't seem to find any LS6 heads for $350... does anybody have a link??
Old 12-30-2006, 02:18 AM
CaptUSA's Avatar
Patriot -----> Follow banner at right of screen.
Old 12-30-2006, 01:32 PM
SVThis's Avatar
its right on the first page...
Old 12-30-2006, 07:20 PM
Cliff's Avatar
Buy a set of ported stage 2 heads with 2.02 and 1.6 valves, you cannot go wrong. You will be happy with the results both on the street and if you want to bring it to the track. I am just about finished porting a set of 243 heads and they are going to be wicked. From 400 to 650 they increase from 250cfm's to 320 cfm's and the exhaust is just as wicked. Good luck!
Old 12-30-2006, 07:35 PM
Irocss85's Avatar
Im gonna guess you meant to say from .400 to .650" lift? Id like to see the pics of those heads. how are you getting that much CFM? sounds really high.
Old 12-30-2006, 07:47 PM
Cliff's Avatar
Yes you are correct. I have a head cold and my brain is on leave........lol. I can send some pictures if you like. I've been porting for awhile and the 243 casting are easy to work on. Looks like you have a nice job on your LT1 heads. LT1 heads will never flow as well as LS6 heads. The angles, design and wall thickness are not the same.
Quick Reply: stock LS6 heads vs Ported LS6 heads
