I have forgotten the exact cam specs....who can read serial numbers on a comp cam?
Old 12-30-2006, 01:51 PM
Mr_president's Avatar
Default I have forgotten the exact cam specs....who can read serial numbers on a comp cam?
well the tittle says it all i need someone to tell me what cam i have by reading you the cam serial number please pm me thanks
Old 12-30-2006, 05:56 PM
Grimes's Avatar
I would....call comp cams up!
Old 12-30-2006, 06:09 PM
hammertime's Avatar
often they will use lobe numbers - that should get you what you need.
depends on whether or not the vendor ground it off though
Old 12-30-2006, 06:14 PM
NoMoreFWD's Avatar
Comp Cams web site has a search by the cam number.
Quick Reply: I have forgotten the exact cam specs....who can read serial numbers on a comp cam?
