running warm after head swap
Old 12-30-2006, 08:55 PM
DLindlZ28's Avatar
Default running warm after head swap
i just got done doing a headswap on my ta and got it all done and now its running warm, anyone no what the problem could be? temp jumped around at first and now it stays around 225. ... also in the driver side head there is a sensor plugged in i broke the plastic connection but still plugs in
Old 12-30-2006, 09:08 PM
The1N_only's Avatar
sounds like you still have air in the system
Old 12-30-2006, 09:14 PM
DLindlZ28's Avatar
how do u bleed the system
Old 12-30-2006, 09:16 PM
DLindlZ28's Avatar
another thing is when i take offf..... the gauge cluster resets it self and the car studders and then back to normal.....
Old 12-30-2006, 09:19 PM
Asmodeus's Avatar
well, getting air bubbles out of the cooling system, jack the front end up so the radiator cap is higher than the engine block, take the cap off, and turn the car on. Let it get to operating temp and the bubbles will work their way out. add coolant as needed to replace the air.
can't say for sure what the other problem is but it sounds like a bad ground on the engine.. probsbly a head.
Old 12-30-2006, 09:22 PM
bfhawki's Avatar
Did you get the head gaskets put on correctly as far as the correct side up so that the water jacket holes are in the right place?
Old 12-30-2006, 09:29 PM
DLindlZ28's Avatar
the head gaskets are on right. i made sure the grounds were good and the sensor i broke is strange when the car is at idel i can unplug it and the car dies out does anyone know what the sensro is its on the drive side head by cycl 1
The1N_only's Avatar
as far as your gauges resetting them self, check to see if your battery is secure... because mine did the same thing when my batter hold down up front broke and the battery would hit the inner fender right there and the car would pretty much die for a second. As far as the cooling system goes do what Asmodeus said, except i dont jack the car up. when it seems full, put the cap on and drive it around the block or something but dont go to far because there still might be air pockets. let it sit and cool down pull the cap back of and top it off and you should be fine. You might have to do that once or twice as well.
Old 12-30-2006, 09:36 PM
DLindlZ28's Avatar
ummm about the battery i just remebered ...earlier i got mad at something and threw a screw driver and it just so happend to stick into the top of my battery..dont know how but i did. it didnt leak anything so i thought it would be fine
Old 12-30-2006, 09:40 PM
The1N_only's Avatar
LMAO.... let me get this right, you threw a screwdriver and it STUCK in the battery? you much have been pretty pisst
Old 12-30-2006, 09:45 PM
DLindlZ28's Avatar
yeeahh i cant even remeber what it was about
Old 12-31-2006, 02:38 AM
Oh4GTO's Avatar
That sensor you broke is the same one that I broke when torquing my heads down. If its on the front of the drivers side than its cyl. # 2 and that would be the water temp sensor.
Old 12-31-2006, 10:45 AM
DLindlZ28's Avatar
can i just glue the plastic piece back on and reuse the sensor or should i get a new one
Old 12-31-2006, 10:59 AM
Hugger's Avatar
The sensors are cheap and you can get them at autozone or advance. I would buy a new one just to be sure that it's not your problem. If the coolant temp isn't reading correctly it can screw up a lot of stuff since many of the tables in the PCM reference the engine coolant temp. Hope this helps.
Jeremiah's Avatar
On the guages resetting, my SS did the same thing and it turned out to be the main hot from the fuse block under the hood being barely loose. The engine would lose power, the gauges would all reset along with all monitoring lights ect. It did this about once a week and drove me crazy for a month or so. The wire had slightly fused/welded itself to the stud and felt tight but it would get hot and come loose once and a while. It had to have been left loose from the factory.
Old 12-31-2006, 11:24 AM
DLindlZ28's Avatar
thanks guy my overheating has been solved due to air in the lines and i bough a new sensor and its working grand thanks for the info and help
Old 12-31-2006, 01:57 PM
bfhawki's Avatar
Glad everything is working right again for you. Congrats and quit throwing screwdrivers.
Old 12-31-2006, 03:34 PM
1BADAIR's Avatar
umm that would be #1
Old 12-31-2006, 04:53 PM
N4cer's Avatar
LOL good catch. That's right.
Old 01-01-2007, 10:48 AM
nxcaaabra's Avatar
good did you ever get the gauge problem fixed??
