Started my cam swap
Started my cam swap
Well I finally started my cam swap over the holiday. When I needed to swing my a/c condenser up thats when i had my first problem. I was being very gentle with the lines and then the hissing sound began
I think i am going to need to replace the upper condenser line. Other than that the cam swap is coming along. I am down to pulling the timing cover to swap the cam/chain/oil pump and then changing the springs/pushrods. (i installed my headers in the middle of all this if you are wondering why its taking so long.)
As soon as I glanced at your avatar, I stopped reading the rest of your post.. Something about a cam-thingy-ma-bob??
Sounds like you are on your way, too bad about the leak in the A/C system.
11Second Club
Don't feel bad about the A/C line. I had to replace the upper line, too. Mine didn't start hissing until like 5 minutes before it was time to fire up the engine. I was like, "**** you, A/C line. I'm about to have 400rwhp."
11Second Club
Originally Posted by TransSlam
I'm installing a TR230 and "**** you, A/C line. I'm about to have 400rwhp." i need to put that as my quote!
