Need help ASAP!!! Motor won't turn over!
Old 01-04-2007, 10:00 PM
14 Second Truck Club
Hemi Killer's Avatar
Default Need help ASAP!!! Motor won't turn over!
Got everything hooked-up on the new motor today. Turned the key over several times without cranking it to build fuel pressure. Went to go start it and it wouldn't turn all the way over. Sounded like the battery was weak, so I charged the batter for about an hour, nothing. Rolled the truck down the driveway and tried to jump start it for about 30min., nothing. Went to Wal-mart and bought a brand new battery, nothing. Then I found a ground wire on the back of the block on the passanger side that I must have overlooked. Bolted it down to the back of the head. Nothing.
Is it possible that I flooded the motor trying to crank it so many times?
Could I have blown a fuse when the ground was disconnected? The other ground wires on the driver side ARE hooked up.
Anybody know of any ideas? Please help!!!
Old 01-04-2007, 10:08 PM
The1N_only's Avatar
have you tried tuning the motor over by hand?
Old 01-04-2007, 10:10 PM
Yeah, it turns over by hand. It actually sounds like it's fixing to crank, but doesn't.
03 BUSA's Avatar
There are also 2 grounds on each side of the block. Is the starter wanting to crank?
Old 01-04-2007, 10:11 PM
Yeah, I can hear the starter. Is one of the grounds on the pass. side on the starter?
Old 01-04-2007, 10:16 PM
The1N_only's Avatar
double check all your grounds and connections, these kind of things can be easily over looked
Old 01-04-2007, 10:18 PM
The1N_only's Avatar
Another set of eyes would probably be benifical to you right about now... because people have a tendency to keep looking at the same stuff over and over. While a new set of eyes can pick up some something
Old 01-04-2007, 10:20 PM
SSNISTR's Avatar
I see you have a Futral cam in there....you might be another victim of the Futral bad cam batch!
If it's one the the bad cams, it was ground 180 out so it won't start....I'd call Futral if it's a recent cam.
Good luck.
Old 01-04-2007, 11:27 PM
It was checked before I got it.
Old 01-04-2007, 11:49 PM
99stealthta's Avatar
does it do anything at all when you turn the key? does every other electrical thing work like headlights, stereo, etc?
Old 01-05-2007, 01:16 AM
Yeah, everything works. It just won't turn over. Where are the grounds at on the passenger side of the motor?
Old 01-05-2007, 02:22 AM
00454sscamaro's Avatar
check the started itself.. if the engine turns over easily by hand and the started making noise trying to turn it- my guess would be a flywheel/starter issue.
Old 01-05-2007, 03:46 AM
DaddySS's Avatar
Let's clarify - when you say it wouldn't turn all the way over - you mean it barely rotates, won't rotate, just clicks, doesn't click, turns over but won't fire?
Old 01-05-2007, 08:02 AM
11Second Club
Gauge's Avatar
+1... can you get a vid even?
Old 01-05-2007, 11:59 AM
It makes an exhuast note for about a second and won't stay up to idle.
Old 01-05-2007, 12:05 PM
erikthegoalie's Avatar
a video would be golden....i bet 5 people would give you a fix if we had a vid..
plug in your coil packs?
Old 01-05-2007, 12:17 PM
raven_450's Avatar
+1 having same problem with my car after my cam swap. so far have Checked physical timing, cam sensor, crank sensor, replaced pcm, tried stock tune, tune from a car running the same cam, fuel pressure is fine, spark is fine.
Sorry to sorta hijack but ive had this problem for about 6 months now and im kinda tired of having a 2001 trans am ws6 driveway ornament x.X
Old 01-05-2007, 05:38 PM
Found the problem! Called Allan Futral and he said it was the VATS. Here is the procedure:
30 Minute Learn Procedure
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON; the vehicle will not start.
3.Observe the SECURITY telltale; after approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes; the vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important
The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password.
With a scan tool, clear any DTCs, if needed. History DTCs will self clear after 100 ignition cycles.
Old 01-05-2007, 05:42 PM
DaddySS's Avatar
Excellent. So for future reference - it turned over but wouldn't fire.
Haven't heard of too many instances where VATS gets hosed due to cam swap so good to know.
