Cam Help.. Newb Questions!!
Old 01-05-2007, 11:23 PM
TORCHD 02 TA's Avatar
Question Cam Help.. Newb Questions!!
So before you say anything, yes i have read the 'cam guide' now can someone put that in english for me LOL!!!! Sorry if i ask a lot of questions, but that is how you learn.
SEE SIG FOR MODS
ok here it goes
I want a good cam, my trans am is not a DD any more, But here is the catch, i am not gonna do any head work. Meaning no P&P heads. jsut want a cam only car. I jsut bought a Ram Air Hood, Lower WS6 Air Box. and i have a P&P TB. Basically i am letting the air get in as much as i can (INHALE) and with my exhaust set up (SEE SIG) i am letting it leave too (EXHALE). So i can some what benefit from a decent cam.
So i was thinking maybe a TR224 or MS3?? But what is this cheaTR cam that i have been hearing about? i want something that will work great with my set up. AGAIN STOCK HEADS... but i was thinking i want the cam to have great low to mid power.. i really do not drive my car to 6000 RPMs everyday and it sees the track 1 maybe 2 time a year. I like to do a lot of roll races.. So what cam could benefit me from that? I would like the car to have a mean, lopey idle! So i was thinking a 112 LSA. I know some friends that have a 112 LSA and drive ability seems to be fine.
Now as far as retainer, springs and pushrods to go with i have no idea on that. I have not really red about that too mcuh yet. So any info would be great.
What about an upgraded oil pump will that be necessary? Do i want the cam to be straight up or degreed? I know that i want an LS2 timing chain
Any other info would be great. Thanks for helping me learn
-Jonas
Old 01-05-2007, 11:32 PM
WS6RED2002TA's Avatar
do you have a m6 or a4
SVThis's Avatar
i like the 231/237 cam on a 112 LSA good mid range cam...and from what i have seen it doesn't need to be spun to high to make great power
Old 01-05-2007, 11:35 PM
sorry i should have stated that. well it is in the sig
M6
thanks
seems a little high to me on stock heads. i wan to get all out the cam with my stock non P&P heads
Old 01-05-2007, 11:39 PM
SVThis's Avatar
there is no such thing is to high on stock heads...the T-Rex(much larger) is "MADE" for stock heads
Old 01-05-2007, 11:45 PM
Cheater cam is a cam by thunder racing (sponser) the cam was designed to be used with the stock manifold but still give you a stock like idle (sleeper). You could still get good results with LT and the cheater cam. Make sure you get a good valve train set up also ie spring.
Old 01-05-2007, 11:48 PM
but the T-Rex is to big for me. so what are my other options? And how is the T-Rex "MADE" for stock heads?
Old 01-05-2007, 11:50 PM
Yea i kinda figured that the cheaTR cam was made by Thunder Racing.. I have QTP LTs on the car. but i think that the cheaTR is a little too small for my application
That is what i need help with, VALVE TRAIN
Asmodeus's Avatar
because it's designed to be the biggest possible cam to fit under stock heads and valves without flycutting.
and you say you're thinking about a 224 and a MS3.. that's like saying you're thinking about a .22 and a machine gun.
Old 01-05-2007, 11:52 PM
I recommend you don't go with the t-rex unless all you care about is mid to top end horsepower.
Old 01-06-2007, 12:03 AM
SVThis's Avatar
i wasn't recommending him to go with the T-Rex...i recommended the 231/237 and he said it was "TOO BIG" for stock heads when actually in today's world its considered to be on the small side...and yes the T-Rex is made for stock heads cause its the biggest u can go without flycutting...and the best way to take advantage of stock heads is with the T-Rex unless u plan on heads later on
Old 01-06-2007, 12:04 AM
SVThis's Avatar
BUT i wouldn't go with a T-Rex
Old 01-06-2007, 12:31 AM
nah i dont car about mid - top end power.
I want low - to mid power
Old 01-06-2007, 12:33 AM
Ok then what are the specs on a MS3? Maybe i red them wrong?
Old 01-06-2007, 12:59 AM
cws T/A's Avatar
Thought this car ran good
TRex cam
http://ls1sounds.com/SLPloudmouth/LM...am_02-cws6.mov
Old 01-06-2007, 03:19 AM
Asmodeus's Avatar
MS3 and TRex are usually mentioned together. I believe the TRex even makes a bit more power under the curve. The MS3 is slightly smaller duration, but a higher ICL.
Old 01-06-2007, 07:09 AM
cws T/A's Avatar
Thunder Racing's "Reverse Split" Camshaft - 230/224 .575/.563 111 LSA 2200-6800 RPM Power Band
http://www.ls1sounds.com/Borla/borla...lsa_notune.wmv
Old 01-06-2007, 11:40 AM
Originally Posted by cws T/A
Wow that car really pulled up top But i think that a TRex is still to big for me?
Now what is the idea behind the "reverse split" cam?
Also when doing a cam you want the exhasut number in this cas to 230 to bigger than the intake 224 right? You always want a bigger exchaust number/ Lift i dont think i am to concerned with. But i want a 112 LSA
BTW i ahve seen this: 112+2 LSA... <----- What does that mean?
Old 01-06-2007, 11:51 AM
The1N_only's Avatar
the +2 means that the cam has 2 degrees advance ground in it
