tsp 5.3 stg 2 heads with tsp 233/239????
will i run into ptv clearance problems with this combo, and what lsa do you guys reccomend, any videos would help, and also what head gaskets should i use for this combo, will stock gm head gaskets be fine? i am in iraq right now so im trying to get all my parts ordered so i can build my ss when i get home
thank you
thank you
When I ordered my 5.3 heads for TSP, I asked about PTV clearance. He said you could run up to the MS3 with these heads and stock gasket. I was looking at that cam, and it will be fine. (this is making gasket assumptions). Your best bet would be call them and ask.
I am going with this same setup, I called them on friday, and they said it will clear fine. I also asked them if I use Cometic head gaskets, and he said he think it might but would look into it for me. Just call them and they will put you in the right deriction
Lane
Lane
Location: Your girl's back door giving her the long stroke while you're at work
Jon told me that 5.3 heads with the 2.02 valves and a MS3 you don't have to flycut. He recommended I go with the 2.02 valves because I'm gonna spray. Yes they make a tool to flycut the pistons. Like everyone has said just call TSP and ask them
