Can LG MotorSports G5 Cam pass emissions?
Anyone know?
I emailed LG and the response was they didn't know but thought it might.
I can't buy a cam that can't pass, so I need to know for sure.
We're allowed 220 ppm in hydrocarbons on the sniffer test. Car will have Hooker long tubes and cats.
Thanks
Anyone know?
Thanks
Re: Can LG MotorSports G5 Cam pass emissions?
Tony,
I can't find out much about the specs other than 112 LSA and probably 226+ intake duration/exhaust duration.
Our sniffer test in North Carolina is at near idle so the HC at low rpm would be the issue indeed.
Can programing clean up the HC at low rpm on a big duration cam by leaning it out? Will a lean base setting on a MAFT clean up the HC for a low rpm idle test? I'm thinking if say 224 duration is the "normal" limit then maybe with tweaking the slightly bigger cam could squeeze by.
All comments welcome.
Thanks
Thanks
I will be getting one soon, and from what I hear from people, it WONT pass emissions.....just because the #'s on it are so radical
that cam on a 112 lobe sep will not pass, i know cause my T1 spec cam (112 L/S) did not pass (HC failed low speed w/ 512ppm w/ a limit of 220ppm). get that cam on a 114, then you may have a chance.
i was wondering what effect durration has on emmisions? tighter=cleaner?
i know lift will not effect it.
SSU Moderator
the B1 has passed. the G5 wont....not in a 112/cam only app anyway. and yes, i know the specs. JWS in Houston was supposed to test his vette soon or just did recently. may want to inquire on the corvetteforum.
Ryan
Ryan
Just an FYI, there is a post on here in recent days about the T1 passing as well. It is a 112LSA, but it has much less duration than the G5 cam.
Todd
Todd
G5
Bear let us know how it turns out, I am very interested in getting this cam.... <img src="gr_stretch.gif" border="0">
