New Engine Question?
Old 01-08-2007, 02:28 PM
7th Darkness's Avatar
Default New Engine Question?
So I was told that the LS1 motor compenents will not fit on to a 350 engine...is this true?
I have a blown engine looking to do a swap... any good places to get a new engine?
Old 01-08-2007, 02:40 PM
MagiC5's Avatar
There are many versions of the SBC... most common is 350. Many referr to the Ls1 as a 350 but it's not... LS1 internals are somewhat interchangable between all Gen III/IV motors.
did you destroy the block or just destroy a piston/rod?
Old 01-08-2007, 02:42 PM
bczee's Avatar
It is more of a question of mounts and brackets.. the compoenents thenself(Alternator, P/S pump, etc) will work if you have mounts and brackets to line up and be driving off of the crank.
Old 01-08-2007, 05:02 PM
Well I am not sure what is damaged, but it will cost just as much to tear it down than to just replace drop and swap due to labor charges.
Basically what I am asking is if I got a 350, could I just drop and swap, i.e. intake manifold, wiring, pcm? Or would I be looking at needed a whole new setup.
Also, is a LS6 plug and play with a LS1 or am I looking at the same issue as the 350?
Old 01-08-2007, 06:19 PM
MagiC5's Avatar
When you say 350 what do you mean?? 350 what???
an LS6 is 100% plug and play.
and just to clarify unless you are ferring to a Gen III/IV motor (ie and LS1-LS7) the head/intake and other parts will not bolt on on old SBC (350)
Old 01-08-2007, 06:48 PM
hammertime's Avatar
What did you blow up and what are you trying to put in its place? What model and year for car and engine.
A 350 is a Gen I Small Block Chevy from 1967 - 1995. 1996 - 2000 350's were vortec truck engines, and still had full interchangable parts.
From 1992 - 1997, LT1 350's were available in 'Vettes, Camaro - Firbirds and Caprice - Impala SS - Roadmaster.
Starting 1997, the LS1 came in 'Vettes, and in 1998 in F-body cars. It is 346 cubic inches, not 350 (no matter what car salesmen might say!)
This is the source of our confusion. Sorry to sounds like a smart ***, no flame intended here
Old 01-08-2007, 07:11 PM
Fratsit's Avatar
Slight correction.
The LT1 did not appear in the Camaro/FB until 1993. Biggest engine in the '92 Z28 was the a 350 TPI.
R/
Frat
MagiC5's Avatar
Great post... I dont' know my SBC history well enough to post something like that.
Old 01-08-2007, 07:30 PM
hammertime's Avatar
Originally Posted by Fratsit
Slight correction.
R/
Frat
True. Same could also be said of LS1's appearing in 97 vettes and 98 f-bods. There were four different small block V8 engines available from the general in 97: Vortec 350 in Trucks, LT1 350 in F-body, LT4 350 in some SLP Firehawks & LS1 346 in Corvette. That doesn't include any 305 truck motors or the discontinued in 96 262 V8 from Caprices.
MagiC5 - Chevy made small blocks in 262, 265, 267, 283, 302, 305, 307, 327, 350 and 400 cubic inches, with bores ranging from 3.500 - 4.125 and strokes from 3.00 - 3.75
