Am I f'ing my sh_t up?
Ok... so I was just thinking. The springs and retainers that I got that I am putting on my car are Patriot Gold Dual valve springs and the retainers and locks are PRC.
These came straight off of my buddies GTO that I thought was an LS1, but is actually an LS2.
Ive only done 1 cylinder so far and the retainers and springs and locks fit in just fine.
One thing I did notice, was that the hole in the retainers and outer diameter of the locks was bigger than my stock retainers and locks.
The inside diameter however is the exact same as my stock ones, so it all fits the valve perfectly. Is this a PRC thing with having a bigger hole in the retainer? Like I said, the part of the lock that fits around the valve is the correct size for my valves, and it all fits and holds perfectly, so what is up with the retainers and locks just being bigger?
Since I am no longer involved with this stuff as much as i used to be I can not answer you for sure, but it sounds like they just use a heavier duty lock and retainer. In other words, they use a wider stronger lock which requires the hole in the retainer to be larger. With the old school stuff the stock locks were 7 degrees, but you could get after market locks which were supposed to be stronger (though this remains debatable) that were 10 degrees, which means that they are the same thickness at the bottom, but since they have a steeper rake to them they are wider at the top, of course then you had to have a retainer to match. Basically, as long as the locks are designed for your size valve stem and keeper groove, and the retainer is designed to be used with those locks (and they are the right size for the springs) you should be fine. Also, from what i have read, the LS1 and LS2 springs and valvetrain should be the same so that should not be an issue.
Originally Posted by seabirdak
Cussing allowed, mods?
LS1 Tech Administrator
Originally Posted by rickyracer25
why are you going to cry about this we are all grown up here and there is no need for that crap if it is gratuitous but it didnt go too far but thanks for the welcome back to second grade did someone cut in line at lunch time or what?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Did you replace the valve seats for those springs? Just making sure you aren't using duals with stock valve seats. I have seen it done a few times...
Im using TEA gold dual retainers with my second set of patriot gold dual springs coils. The patriot, PRC and TEA gold dual spring coils are all identical. The retainers locks and seats may be slightly different, especially patriot, though theyll all set you up at 1.800 install height.
