newbie h/c advice
newbie h/c advice
i plan on putting a h/c package on this month and was wondering what yall suggest for an 02 ss m6 w/ pacesetter LT, catted y, borla...DD so don't want anything too extreme
Comp Cams Xtreme RPM Hydraulic Roller Cam, 224/228 duration with .534/.537 lift and 112 LS
AFR 205cc Mongoose Street heads
also what i might need to strengthen it all up to ensure that it lasts
thanks
thanks
thanks
thanks
With those heads...contact Tony Mamo of AFR and get the 224/228 .581/.588 cam he sells for those heads. If you want a little more, consider a LSK cam with similar specs to the one in my signature or Patrick G's car. Patrick's is a 110+0 LSA and mine is a 114+2 LSA. You would have to use the AFR 8019 springs or equivalent to optimally run our cam.
Hammer
Originally Posted by itsok_ok
wouldnt the 223/227 cam have less power?....yeah imma newbie..so sorry if my questions sound dumb, but im in the same boat looking at this h/c combo (except im an a4)
Hammer
thanks
thanks
so what difference in power/torque would the lsk lobe 223/227 make over the xer 224/228 ones make...and where in the power band (ie: low, mid) comparing the two. How would i go about deciding on a cam for an a4 as far as lobe and lsa because i know the tuning is an issue when compared to the m6. i think its safe to say both bryan and i are pretty drawn with the AFR 205, but its mainly the cam where we need more of your guys help. oh yeah...what about the chamber of the heads (ie: 61cc, 63cc).
k thanks alot for the advice! I'de like to do the install myself but don't have the tools or the time. What do you think install and tune would cost me for that set up?
i'd say you're looking at over a grand for an install and tune. the lsk lobes verses the xer lobes are probably good for 10 or alittle more rw.the xer lobes put up great numbers and even a spring like the comp 918s will generally last well over 15k.
1 Post
At LG Motorsports you can get an X series cam of your choice and AFR 205's for less then 3 grand. As far install and tune, you'll have to give Bobby a shout. I under your SIG that you are claiming Dallas Ft Worth. Not tooooo far from Wylie? Less then an hour right?? Go check out theie website www.lgmotorsports.com
Good luck. See numbers in my sig for a taste of what they can do for you.
what is a good cam for set up??? I will throw out my options, then you tell me what to change... Still a newb at this cam stuff....
ok here for my mods SEE SIG!!!!!!!!!!!!!!!!! Car is a M6
cams:
TR224: 224/224 .563 / .563 112 LSA
TRak: 231/234 .640 / .590 112 LSA
double roller chain, Comp 918s, Chromolly 7.4 rods, LS6 Oil Pump, Stock Lifter. What about retainers and valve seats?
And what is the Comp XRE?????
sorry i have red a lot and still am trying to get all this to sink in
Thanks
EDIT: Do i want to degree the cam or line it straight up
cams:
Thanks
I love my TRAK cam. It may be a little big for what some consider a daily driver, but I have driven daily for over 10,000 miles with no problems, albeit I have an awesome tuner (Jeremy Formatto) Makes crazy power and drives perfect with 4.10 gears.
At the bare minimum you would need
new timing chain
new springs
hardened pushrods
gaskets/seals
bolts/studs
tune
highly recommend a new oil pump and possibly new lifters depending on milage and year of the engine.
variable depending on head and cam setup as to what you would need for those though.
new timing chain
new springs
hardened pushrods
gaskets/seals
bolts/studs
tune
new timing chain
new springs
hardened pushrods
gaskets/seals
bolts/studs
tune
new timing chain
new springs
hardened pushrods
gaskets/seals
bolts/studs
tune
My car is a 2002 M6 Trans Am. Not a DD anymore. car has 41K on it..
again.. Comp 918s or 921s, LS2 timing chain, SVO 30# injectors, LS6 Oil Pump, Chromolly 7.4" Pushrods. I think i should be ok with the Lifters. But i dont know about retainers....
What else and would this be an ideal set up?? Basically a street car, sees the track 1 maybe 2 times a year.
Any more help
