383 Ls1
Old 01-12-2007, 11:19 PM
What's a Sticky?
97MysticZ's Avatar
Default 383 Ls1
Hey guys, I'm looking at buying a camaro with a 383 LS1 in it. Its really set up for the street, so I was wondering how many miles you think that the motor could take before it needs a rebuild- just strictly street driving with only a couple passes and not a lot of abuse at all. The motor was completely gone through and built. Also, how much hotter do you think that it will run as compared to stock (with stock water pump)???
Old 01-12-2007, 11:20 PM
SSNISTR's Avatar
Are you sure it's a 383 LS1 not a LT1?
USUALLY LS1 strokers are like 382's.
Old 01-12-2007, 11:24 PM
What's a Sticky?
97MysticZ's Avatar
I was told its a forged 383. This is about all of the info I have on the motor as of now.
CNC ported 5.3 heads hand finished 2.055 intake valves
Comp Double Roller timing chain
Katech ported oil pump
Comp hardened push rods
LG Motorsports G5X2 Cam
Eagle 4” crank
Lunati Rods
Mahle pistons 3.903”
Old 01-12-2007, 11:26 PM
SSNISTR's Avatar
Eagle 4” crank
Lunati Rods
Well if that's it, sounds like a nice set-up.
Old 01-13-2007, 10:52 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
An LS1 will be a 382 if it is only a stroker 4" crank (with stock 3.898 bore). If they bored or honed it out to 3.903 or 3.905, it will be a 383 with a 4" stroke crank. Longevity will depend on how well it was built. I'd find out who built it, and check their reputation if at all possible.
Old 01-13-2007, 12:44 PM
Black02SLPSS's Avatar
Wait wait so you can make an ls1 a 382 without boring it over just by poping the oilpan out and swaping crankshafts? Im kind of a newb but if thats all it takes im game for that.
Old 01-13-2007, 12:56 PM
Mikey 97Z M6's Avatar
No, you can't lol...! You can build an engine without overboring it, but if you're replacing the crank with a longer stroke, you HAVE to change pistons (dif compression height), or go with a shorter rod to compensate for the longer stroke. Besides that, any time you change a component in the rotating assembly, you'll need to re-balance it.
Mike
Old 01-13-2007, 01:00 PM
yeah i figured that sounded too good to be true. oh well didnt quite think about that before i said what i said
Old 01-17-2007, 12:30 PM
What's a Sticky?
97MysticZ's Avatar
So what do you guys think? Any thoughts or comments on a 383 LS1? Things to look for? Are they good motors?-- considering the parts I listed a few posts up
