Should I stick with my T-Rex, or should I get a custom spec'd cam?
Wondering exactly what I put in the title... stick with a T-rex v.1, or sell it and get a custom spec'ed cam? Mods are as follows:
PRC stage 1 LS6 heads
LS6 intake manifold / Ported stock TB
Pacesetters /w bullets off of the headers
Stock bottom end /w new rings and new bearings
42lbs injectors and new fuel pump
Full suspension
Textralia OZ700 Clutch
Speed Density Tune
Any input is appreciated, thanks!
P.S. Forgot to say that I am mainly looking for a max effort cam for my car, and was wondering if it would be worthwhile to pull out the old t-rex and get something custom spec'ed. Also, I am not afraid of high duration, high lift, low LSA cams.
Full suspension
Speed Density Tune
It depends on what you want from your car. I swapped my T-ReX for a 228/232 and I couldn't be happier. The car is much easier to drive and has a more enjoyable power band. My car is only driven on the street though, so if you're always at the track the T-ReX may be just what you need.
Josh
Josh
Josh
Josh
Originally Posted by GuitsBoy
Are your pistons flycut? Youre not gonna be able to fit much if any more cam over stock pistons before you hit P to V issues. Sure you could put more cam in there, but then again are your heads up to the challenge?
