Head Gasket Q
Old 01-17-2007, 06:35 PM
CamaroSS_2002's Avatar
Default Head Gasket Q
LS1 cylinder head gaskets (98-01 F-body, 97-01 Corvette), pair = 12498543
LS6 cylinder head gaskets (MLS) (02 F-body, 02-04 Corvette), pair = 12498544
I have a 2001 block. Can I use the 02-04 Gasket and is it better to use? To my understanding it's the MLS Gasket
I plan on stock compression, just changing heads and cam to different ones. No boost, yet.
Old 01-17-2007, 06:39 PM
NemeSS's Avatar
can use either,
but the mls should be favored over the graphite one if your block was decked and heads were milled,
if its just to replace a head gasket with no machine work done to heads and block, then stick with the graphite ones, the first version non mls ones
Old 01-17-2007, 06:41 PM
ls1muscle's Avatar
Originally Posted by CamaroSS_2002
No boost, yet.
If you have plans for boost, go with MLS.
Old 01-17-2007, 06:49 PM
Originally Posted by ls1muscle
+1
I figured it would work, wanted to be sure before I placed the order. Thanks everyone
