Which cam will work best with AS 5.3 Stage 2.5 heads
Old 01-18-2007, 08:21 AM
Restricted User
2001 Pewter WS6's Avatar
Default Which cam will work best with AS 5.3 Stage 2.5 heads
I am trying to put a combo together for a friend that will put down some good track times yet will still be drivable on the street. This isn't a daily driver. The cams we are considering are the T-Rex the MS3 and the G5X3 or G5X4. He already has the heads. It is a stock cid bottom end. Flycutting isn't a problem. Thanks in advance for your input...
Old 01-18-2007, 09:23 AM
PREDATOR-Z's Avatar
That is a very vage question.
All of these can be "driven", so what I'm gonna do is list by potential, fastest to slowest
T-REX
MS4
MS3-G5X4
G5X3
Old 01-18-2007, 09:39 AM
Restricted User
That was the kind of answer I was looking for... He just wants a fast runner. The car has 4.10's and a 4000 stall converter and the other bolt-ons.
Old 01-18-2007, 09:57 AM
N4cer's Avatar
T-REX
MS4
MS3-G5X4
G5X3
As far as duration, the X4 is bigger than the MS4. Why is the MS4 listed above it? Do the bigger lifts make up for that?
Old 01-18-2007, 08:29 PM
Restricted User
Is there going to be a big difference in performance between the G5X3 and the T-Rex?? I know the G5X4 would be a closer match but we are running Comp 977 springs and I don't think they will handle the lift of the G5X4.
Old 01-18-2007, 08:38 PM
N4cer's Avatar
T-rex has more lift than a G5X4. Barely. But still more.
And yes, there's a big difference between the X3 and the Trex. The Trex is all up top, while the X3 is mid and top with drivable low end. I have no problem cruising around at 1500rpm with my cam. I haven't driven a Trex car, so I could be wrong. I've just seen the clutch from a car that was a Trex car that didn't have enough gear.
Old 01-18-2007, 08:55 PM
Restricted User
What is the duration and the lift on a G5X4???
Old 01-18-2007, 09:06 PM
N4cer's Avatar
LG hasn't released that info, and I don't feel like starting trouble by releasing it either.
