Is this the right cometic gasket?
http://www.cometic.com/da_viewimage.aspx?da=173
Is it the right one? I want a .040 MLS gasket. I ask because it is way cheaper then I see on vendors websites and the description says darton sleeves, whats up with that?
Originally Posted by ArcticZ28
That's not cheaper, it's more expensive than I've found them. That price is for one gasket, not the set. Regardless, I don't believe you want the one for a mid sleeve, you just want a cometic 3.905" for the stock bore LS1.
