how much can a 241 head be milled with a MS3?
Originally Posted by chrs1313
Is this a good idea any negative affects how much will power increase over non milling? thanks
Chris
Chris
how can a 5.3 head be about at the max with stock gasket for piston to valve clearance and a stock head be the same...i guess how much of a difference are we talking between stock heads 241's and 5.3 heads...because i know for a fact that 5.3 with a stock gasket is about the closest you wanna go...
