Rev Limiter?
like posted above you want to set it were the power starts to fall off. for example my 230/224 started to fall off at about 6k, so i had my limiter set at 6300. this way when i shift ill be right back in the powerband.
I wouldn't go higher then 65k with stock bottom. see where the cam starts to drop and I would set it about 300rpm's past power drop off so when u shift u r at the powerband.
fuerzaws6
fuerzaws6
