408 and alot of horse..
Old 01-23-2007, 09:33 AM
ss408ss's Avatar
Default 408 and alot of horse..
Hi guys. I been doing some research around here and I have asked a similiar question a few times on other boards.
If you were to build a iron block 408 and wanted 500+ to the rear wheels or horse and similar numbers (lets say 475 rwtq) how would you go about it?
I dont want a CRAZY cam. I had the ms4 and I rather not that radical.
thanks.
Old 01-23-2007, 09:55 AM
baldurann's Avatar
Give one of the bigger engine builders a call, and have them spec a cam out for you. Or better yet, just have them build your motor.
Old 01-23-2007, 10:21 AM
ss408ss's Avatar
Yeah I hear ya. I think today I am gonna have one built for me. I been saying that for awhile but I think today is the day.
I was just curious what people have DONE to see the horsepower increase. I always like having a second, third, and fourth opinion before I pay 10 grand for something.. ya know?
Old 01-23-2007, 10:45 AM
Andrew91GT's Avatar
You need a larger cam for more cubes... an MS4 in a 408 will not be as radical as an MS4 in a 346.
Old 01-23-2007, 11:54 AM
as35thss's Avatar
See my sig. The cam seems to be what most guys are running. The heads are to small. Need the 225s. Mine did 482hp on a low known dyno with 4.10 gears. Not broke in yet.
Old 01-23-2007, 01:50 PM
ss408ss's Avatar
thank you.
thinking of the livernois heads that flow 360cfm.
Old 01-23-2007, 03:07 PM
camarokid94's Avatar
i will have close to the came setup and should be about the same numbers hopefully higher
iron 402 AFR205s milled to 59 244-248 113+4 cam 1.75 headers 11.66SCR 8.5DCR mamo ported fast 90/90 im hopin with my 9in to hit 500 and 480TQ
Old 01-23-2007, 04:25 PM
Sigforty's Avatar
Try reaching Futral they have some nice custom grinds.
Old 01-23-2007, 05:08 PM
slow trap's Avatar
numbers in sig.this setup is definitely not optimized but still a decent combo.
Old 01-23-2007, 06:47 PM
02Z06MATT's Avatar
If you are looking for big hp #'s then you need to make sure you have heads that will breath good enuff. the motor is only as good as the heads, what good is a big cam if you cant get enuff air into the motor in the first place. I went w/ a 402 w/ a fully ported ls6 head flowing 320 cfm and a custom grind 248/254 112lsa and I am making 560 hp to the wheels, so if you are looking for a lot of hp make sure you get a good set of heads
