Cam gas mileage and driveability TSP 231/237
Old 01-23-2007, 08:00 PM
marcdez's Avatar
Default Cam gas mileage and driveability TSP 231/237
Cam gas mileage and drivability on a TSP 231/237 cam. I want to know from anyone that has had a similar cam. What the gas mileage was like and how was the drivability. I am thinking of installing this cam and selling the lingenfelter cam that I currently have installed since it is more of a stealthy cam or would be better used for a supercharger set up. Any and all input is good. I just want to know because I use my car as a daily driver and need something reliable that is not going to be shutting off every stop light and not going to kill me at the pump if I drive normally most of the time and floor it when I got to the track.
Thanks for the help
Old 01-23-2007, 11:30 PM
00LS1SS's Avatar
You know a couple years ago I had one in my SS and I loved it.My neighbours hated it. It never stalled at lights. Its really not that big that you need to worry about it. Plus the tuning out there is even better than when I did it. I say do it and dont look back, it screams like a nascar especially with the GMMG and LT's and does make the power up higher in the band. If you were driving in traffic for hours every day for months on end it might get on your nerves after a while but you would have to drive it alot. About the mileage it definately declined over stock but I think I got around 20-23 HWY mpg if not mistaken and 12-17mpg in town all depending.
Old 01-25-2007, 10:35 PM
marcdez's Avatar
Thanks for the help and thats a nice C6 if I could afford one that would definately be my preference to. I am going to go ahead and get his cam and install it. Thanks again for taking the time to respond.
Old 01-25-2007, 11:09 PM
blkZ28spt's Avatar
Get gears, 3.73 or 4.10, first. If you get a good tune it'll drive perfectly fine for a daily car.
Old 01-25-2007, 11:32 PM
00LS1SS's Avatar
Oh yeah bye the way I also had 4:10's . You will be happy you got them. I am now looking back at some old notes and I actually got better highway mileage than that...Sometimes up near 26mpg. Hope it all goes good for you.
Old 01-26-2007, 07:06 AM
brad8266's Avatar
26 highway with that cam is really good, hopefully it works out that way for me.
Old 01-26-2007, 07:20 AM
01Z0H6's Avatar
I ran a similar cam Comp 232/236 .595 .601 114 in my stalled A4 with bolt on's....LS6 heads etc...
I still got 19-20mpg hwy... alot less in the city... and my neighbors hate me as well..
It all depends on that right foot...
Good luck..
Currently having a G5X....? put in my car... My neighbors will probably protest!!
Old 01-26-2007, 07:29 AM
kent seay's Avatar
im thinking about that same cam also but i know the springs have to be changed in mine and there kinda high i drive mine everday so im interested in the gas mileage i still need more info on why i gota change my springs to the double springs my springs are brand new so im a little leary about changing them
Old 01-26-2007, 07:33 AM
01Z0H6's Avatar
Your stockers won't hang with that cam...
Old 01-26-2007, 07:44 AM
kent seay's Avatar
i dindt mention i got the 918s comp cams htey only go to 600 lift i believe thats why hawks third gen parts done a 595 to be on the safe side on the cam
Old 01-26-2007, 09:11 AM
LS1TECH Sponsor
Steve Burger's Avatar
4.10 gears 6 speed and that cam 28 on the highway.
Old 01-26-2007, 09:15 AM
kent seay's Avatar
thats pretty decent for the gear ratio also for the gas mileage
Old 01-26-2007, 06:03 PM
marcdez's Avatar
I thought you could use the 918 with NP on this cam. If you are going to upgrade to dual springs you might want to lok in to the thunder racing trak cam better torque and you wouldnt have to get the gear because of the HP under the curve just an idea. Those dual springs are expensive to.
Old 02-03-2007, 04:09 PM
kent seay's Avatar
sorry for the late post but yes the dual springs are rediculosly priced but i was told the 918 will only hold to a 600 lift.
Old 02-03-2007, 04:14 PM
2 SSlow's Avatar
i run 918's on a 233/239, .598/.605 cam. The car drives really well...minimal surging/bucking. I still cruise 60mph in 6th gear, sometimes even less. I average 18-19mpg combined city/highway...I have gotten 26mpg on a road trip untuned though..
Old 02-03-2007, 04:50 PM
2QUIK4U's Avatar
I run a similar cam TR 230/237 .600 lift. 112 LSA. Upgraded springs are a must. I dont have any problems with drivability. I get 18-20 mpg around town and about 26 on the highway.
Old 02-03-2007, 05:32 PM
SVThis's Avatar
i run comp cams (not from TSP) 231/237 .585/.595 112 cam with patriot stage 2 (59cc)heads with a 3.42 stock gear...i get some bucking/surging rolling through parking lots and things at under 1500 RPMS but nothin really bad...when i got it tuned it made right at 440 RWHP and a lil bit over 420 RWTQ so its a TQ monster...it runs low 7's in the 1/8th with stock gear....and about the MPG, im not really sure down to the mile but i can tell u it gets better gas milage than my Daily Driver Auto V6 Grand Am
BTW, for u guys running a 4.10 gear with this cam...do u wished u would have stayed at 3.73 or higher?I talked it over with my performance guy and he said that 3.42's were a good match for this cam, but if i was lookin to change he wouldn't go with anything over a 3.73 because of how much TQ this cam this car makes
Old 02-03-2007, 06:51 PM
Prophecy's Avatar
i got a 232/238 .605/.605 112LSA and have no drivebility issues... and gas mileage fell a little but not much.
Old 02-04-2007, 03:29 PM
kent seay's Avatar
that sounds like u got a decent setup im just learnin about these ls1 motors im about to build my own it will be my first engine build and i am 22 years old and i have never seen the inside of an engine yet i just have replaced heads and minor things but on the extra ls1 i got ima go with the ms4 it sounds like the best race cam i can get so i can still drive my car at least ever other day or so
Old 02-04-2007, 04:42 PM
00LS1SS's Avatar
I had 4:10's and would never change back.
I still clearly remember finishing the gear install with a helper at midnight or later, and cold starting it , letting it idle for a few minutes to warm up as it was getting near winter, and how it was snapping and cracking at the moon with that gmmg exhaust and porch lights all over my crescent turining on ,one by one !!!
