tsp tourquer 2
Old 02-03-2007, 02:04 AM
Mach1killerls1's Avatar
Default tsp tourquer 2
i'm in a position right now where i have some cash to finally put a cam in my car its a basic bolt on car with a 125 shot of spray. i'm lookin into the tourquer 2 with tsps cam pack an ls2 timing chain and a ls6 oil pump. just wondering what some of your thoughts are on this cam and just curious what type of hp and trq gains i'll see .
Old 02-03-2007, 05:06 AM
PREDATOR-Z's Avatar
If you get it get the 112+2
Old 02-03-2007, 05:07 AM
mcamarols1's Avatar
numbers in the sig, very streetable, gets 26mpg hwy, and like 10-13mpg(depends on ur foot) on the street,w/ the 3.73's, i like it, nice lope too
Old 02-03-2007, 08:40 AM
crazylane's Avatar
Is that a conservative tune?? Those numbers seem kinda low, I am not trying to bash just wondering, I would think with thos heads and that cam you would at least be pushing close to 420hp.
Lane
Old 02-03-2007, 08:42 AM
PREDATOR-Z's Avatar
Could be Mustang dyno
Old 02-03-2007, 10:14 AM
1baddls1's Avatar
i thought the torquer 2 was straight up???
Old 02-03-2007, 10:26 AM
PREDATOR-Z's Avatar
They can grind anyway you like
Old 02-03-2007, 07:51 PM
mcamarols1's Avatar
Lane
tune was by TSP at wolfworth, dyno was on a dynojet
thats the same thing i said , i dont kno, i asked TSP what was wrong with my setup cause i seen peeps w/ a cam alone pushing 400whp, they said if i dynoed it b4 the cam and heads, she made 333 full bolt ons. thats a 73whp.
i think that since im running un-milled 243's, stock head gasket, stock pulley, unported stock TB, ls6 intake, and through a 12bolt, and my heavy z06 knock-offs, thats where my 20-30whp went
what u'll think?
Old 02-03-2007, 08:56 PM
crazylane's Avatar
what u'll think?
Yeah you are loosing a lot of power through various things, But even if the dyno said that you only had that much, it don't mean nothin except for numbers, Take it to the track and it might surprise you...
How does the cam act at slow speeds?? Like around town??? I am interested cause I am thinking about going different than A 233/239.
Lane
Old 02-03-2007, 09:09 PM
Stang-Slayer's Avatar
I love my torquer v2......LOVE IT! Cam only and look at my numbers....and this is on a shitty *** tune too
Old 02-03-2007, 09:20 PM
eLTwerker's Avatar
What #s homie?
Old 02-03-2007, 09:27 PM
mcamarols1's Avatar
Lane
its really good around town, it used to surge alil, but i fixed it via HPTuners , it doesnt like to cruise under 1200rpms, above that its almost stock
b4 i fixed my surge and idle issues it would turn off comming to a stop, so i went into hptuners checked my iac steps and they where maxed at idle, so i re tuned my TPS(adj. idle screw & reset the TPS) and i got my steps in the 20-30 range when its at full temp, and now i have no issues,
i do need to go to the track though, ima get my line-lock hooked up, and buy me a set of draglites and some ET streets and see what she does i love the cam though, and to think i wanted to get a Z06 cam b4
Old 02-03-2007, 09:28 PM
mcamarols1's Avatar
Originally Posted by eLTwerker
What #s homie?
+1 yea what he said
Old 02-03-2007, 09:41 PM
I got the ssame prob.....Surges at idle.....Dies on me if i turn my wheel and press break without giving any gas....
Also dies on me when im coming to a stop......I dont know this really did but I Figured out my egr plug came loose.....I put it back in and made sure it sealed good and now i have no probs withit.....except it idles high at 1500rpms now lol......beats me im confused
Old 02-03-2007, 09:56 PM
mcamarols1's Avatar
vacum leak maybe????
Old 02-03-2007, 10:10 PM
Is that a vacuum prob?
Im guessing its just more air coming in then what the maf is feeling....
I dont know....i cant imagine it was that much air cuz im pretty sure it was on pretty good b4....lol who knows....
I ran REALLY RICH b4....i always thought it was the tune.....
Its weird......lol doesnt matter....it finally started driving good today and then the tranny went out haha!
Old 02-03-2007, 10:50 PM
mcamarols1's Avatar
sucks about ur tranny bro,
did u make the hole in ur TB bigger?
did u check ur PCV lines?
did u check ur brake vacume lines?
defective IAC valve?
could be a number off things, good luck hope u solve ur problem
Old 02-03-2007, 10:54 PM
I always figured it was the tune......what hole in the tb u talkin about ?.....my tb is still stock......what am i checking the pcv lines for>?
Same thing with brake lines....
IAC valve?
Lol now i feel like a dur dur douche bag lol....
Old 02-03-2007, 11:28 PM
mcamarols1's Avatar
IAC valve?
sorry mach killer but lol jk
it can be the tune, if u had a egr prob when u where gettin ur tune they prolly compensated for it while doing the tune, but i think its very unlikely
since u have a stock TB the hole in the TB blade is stock so thats out of the question(some people drill it bigger to solve thier idle issues, i did it via my idle set screw and reset the TPS)
the PCV lines check the one that goes into the intake manifold. check to see if its sealed or dryrotted or cut
as for the brake line, i ment to say the line that goes from the back of the intake manifold to ur brake booster(i think thats what is called), check to see if its dryrotted or if its cut same as the PCV
the IAC valve could be stuck in the open position, allowing more air into the engine, but i dont kno how to check for a faulty one, (this happened to a friend of mine thats why i said check the IAC)
u want all the air to be measured through ur maf, any air that goes into ur engine un measured can cause a lean conditon, maybe someone w/ a lil more experiance on the subject will chime in
Old 02-04-2007, 01:36 AM
1baddls1's Avatar
ordered diectly off their website chooseing the 112 lsa they grind +2 into them off the menu??? unless requested otherwise?
sorry pat - we love you
