111 Lsa?
Old 02-03-2007, 01:58 PM
jetlag's Avatar
Default 111 Lsa?
I've been looking for cams and found on that is a 228/228 .588/.588 111LSA and its a custom Comp Grind...
is 111LSA too much? Will it be REALLY choppy/lopey?
Old 02-03-2007, 02:02 PM
blue98Z's Avatar
very choppy/ lopey.
Old 02-03-2007, 02:22 PM
LS1 Tech Administrator
Patrick G's Avatar
The amount of chop is directly related to the amount of overlap. Let me give you an example. The cam you're talking about: 228/228 111LSA has 6 degrees of overlap at .050".
An MS3 cam is 237/242 114LSA and it has close to 12 degrees of overlap. Guess what? The 237/242 114 LSA has a much harder lope than the 228/228 111LSA cam. Overlap is what gives you the lope.
For what it's worth a 220/220 108LSA cam would be the smoothest idling cam of the 3. How could that be, it has a 108LSA? Because if only has 4 degrees of overlap.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 02-03-2007, 02:35 PM
jetlag's Avatar
Thanks Patrick!
Old 02-03-2007, 07:12 PM
mr2guru's Avatar
So 23* of overlap is gonna rattle the teeth at idle?
Old 02-03-2007, 07:19 PM
DONAIMIAN's Avatar
No, my next cam will rattle the teeth at idle
Old 02-03-2007, 09:00 PM
crazylane's Avatar
Whats the formula to figure out overlap??? I searched but could not come up with anything
Lane
Old 02-03-2007, 09:02 PM
silverbandit0996's Avatar
id also like to know the formula to that one?
Old 02-03-2007, 09:49 PM
SSNISTR's Avatar
Me too....
Old 02-03-2007, 10:04 PM
eLTwerker's Avatar
J rod posted a valve events calculator(it's a sticky in the Adv. Tech section). It'll give you the overlap. Just plug in the duration, LSA, and ICL.
Old 02-04-2007, 12:17 PM
DONAIMIAN's Avatar
ICL dosent change ovelap
Old 02-04-2007, 01:02 PM
JPH
JPH's Avatar
Lane
@.050 ivo # + evc #=overlap *
Old 02-04-2007, 03:51 PM
TheLS1Kid's Avatar
intake duration+exhaust duration
divide by 4
subtract LSA
multiply by 2
the higher the valve overlap the choppier the idle
Old 02-04-2007, 08:20 PM
StreetLethal01's Avatar
So a 228/228 with a LSA of 112 would be at 4 degrees of overlape and the 111 LSA would be at 6 degrees of overlape. Would there be a diffrence in hp and tq or just the idle?
Old 02-04-2007, 08:47 PM
spazzyfry123's Avatar
The power band will be brought down with a lower LSA.
Old 02-04-2007, 08:58 PM
dpw41285's Avatar
that sucks im only at 10deg..i was hoping more
Old 02-04-2007, 09:06 PM
cav101's Avatar
so how do u calculate a 112+2....where do u factor in the advance that is ground in?
Old 02-04-2007, 09:11 PM
crazylane's Avatar
thank you
