can you use lt1 retainers for ls1's??
Old 02-05-2007, 10:40 PM
Taubr Unit's Avatar
Default can you use lt1 retainers for ls1's??
I know the 918 springs are interchangable but are the retainers also?? My buddy bought 918 springs/retainers/locks but it was all off a lt1. I know the springs are interchangable but can he use the retainers/locks too?? I saw someone said the valves on ls1's are different then a lt1. Can someone conferm this?
Old 02-07-2007, 02:58 PM
Taubr Unit's Avatar
anyone?
Old 02-07-2007, 03:00 PM
speed_demon24's Avatar
The LS1 valve stem diameter is different so you can't use the locks.
Old 02-07-2007, 03:01 PM
Taubr Unit's Avatar
but can you use the retainers still? I would assum so, ill just need to buy different locks?
Old 02-07-2007, 03:03 PM
I would think so if the outside diameter & angle of the locks is the same
Old 02-07-2007, 03:18 PM
1997bird's Avatar
They use different retainers as well as different valve locks. There is a .028" differance in valve stem dia (11/32" is .3415" and 8mm is .3135").
