Car doesnt want to idle
Old 02-06-2007, 09:06 AM
Dustin98SS's Avatar
Default Car doesnt want to idle
Hey guys, I've had the GM Hotcam in my car for around 4 years. Idles fine with no tuning. Car runs strong. Today when I got in I started it and it wasnt wanting to idle. It would surge a little but stay around 400 rpms. It usually idles right at 1k no problems. I had to keep hitting the gas at stoplights to keep the car running.
When I got to work it died. I started it up and it idled right at 1k. I gave it some gas while it was parked and it surged and died. Any ideas? I'm hoping it is just spark plugs. I changed the plugs when I did the cam install and would say I've got around 30k miles on the car since the cam swap. Any help would be greatly appreciated.
Old 02-07-2007, 09:52 AM
dameter21's Avatar
Do you have a code? check opereation on idle air control they usually go bad and cause this, and also check for false air(vacuum leak) on the intake side.
Old 02-07-2007, 09:54 AM
brad8266's Avatar
plugs,wires first, especially since they have 30k
Old 02-07-2007, 09:58 AM
Andrew91GT's Avatar
Bad IAC, plugs, wires, coil, etc.
