milling head and gasket quetions.
Old 02-06-2007, 12:33 PM
92slowmaro's Avatar
Default milling head and gasket quetions.
ok so im thinking about going with the tsp cnc ls6 heads as well as the torquer v2 cam. now i want to mill the heads for the extra compression and power.
now i was thinking milling them .030 and getting a .040 head gasket. with the torquer v2 will this be to much? or should i just run the oem head gaskets.
thanks,
ryan
Old 02-06-2007, 02:51 PM
caviness's Avatar
i know the .040 head gasket will be better.how much to mill maybe somebody can run SCR DCR for ya.stay around 11.3 SCR and 8.7 DCR for 93 gas.
Old 02-06-2007, 03:36 PM
92slowmaro's Avatar
yeah i dont want to go over 11.1 really but we will see and i also dont want to flycut.
Old 02-06-2007, 05:33 PM
1baddls1's Avatar
if you milled the heads .030 you'd be @ 58cc + .040 gask your SCR would be apx 11.97 with DCR of 8.89
not very pump gas friendly & def worry about PTV issues
personally i'd mill for a 61cc (.015 mill)
& def keep the .040 gask for a better quench
if your looking for only 11:1 comp keep them stock chamber (64cc) & run .040 cometic & you'll be @ about 11.04 SCR & 8.22 DCR
