G5X2 cam...will 26.6 lb injectors support this?
Old 02-06-2007, 03:08 PM
NOBR8KSS's Avatar
Question G5X2 cam...will 26.6 lb injectors support this?
I have a 99 Z-28 and I am in the process of swapping the cam to a G5X2...will the stock 26.6 lb injectors suffice? or do I need to upgrade to 30 lb?
Old 02-06-2007, 04:24 PM
z28misfit's Avatar
Well put it this way I'm running the G5x4 with stock injectors on my 99Z so you'll be fine. Look at my sig, I'm also over 400hp to the wheels. TSP said usually h/c cars are ok with stock injectors.
Old 02-06-2007, 05:00 PM
2 SSlow's Avatar
i have a TSP 233/239 on a 2000 SS with stock 26.6lb/hr injectors. I am at like 88% duty cycle at WOT. I know that cam is similar sized, and i have the smaller injectors...you should be good to go!
Old 02-06-2007, 05:13 PM
01Z0H6's Avatar
I am running the G5X3 with the SVO 30's...
Your stockers should be fine..
I have some 28.8's... if you need em... pm me if interested...
Old 02-06-2007, 07:10 PM
purdueranger's Avatar
stockers from my 00 worked fine but with the X4 on a colder day = way lean.
Old 02-07-2007, 09:17 AM
NOBR8KSS's Avatar
Thanks guys...I will try it out with the stockers and check the duty cycle during tuning.
JC
Old 02-07-2007, 09:18 AM
SSpdDmon's Avatar
You can find lightly used 28.8's for ~$50. Not a bad idea if you ask me...
Old 02-07-2007, 09:20 AM
DONAIMIAN's Avatar
Last time I saw an acceptable duty cycle with my stock 26's was at 4500rpm's....this was with a T1.
Old 02-07-2007, 03:59 PM
NOBR8KSS's Avatar
OK...I'll look into a used set of 28.8s
Old 02-13-2007, 02:44 AM
SLP4CamaroSS's Avatar
ttt... im getting the same cam and like to know lol
Old 02-13-2007, 10:43 AM
J's99Zrated's Avatar
I have a 99 Z28 and I was maxing out stock injectors w/ 375rwhp on a h/c car. I had TEA 5.3 stage 1.5 and a 224/228 on 114lsa cam.
Old 02-13-2007, 02:51 PM
wouldnt yr heads supply more air which will make your car run lean cuz of the unadded fuel????
Old 02-13-2007, 03:25 PM
Sneaky's Avatar
It's all about the duty cycle that you end up pushing your injectors too.
Yes, your car will be fine with stock injectors and a cam. Most H/C cars will run fine with stock injectors, but alot choose to upgrade to get their duty cycle back down to 80% where it's desired.
If you can get some 28's at a good price i would go that route. You will be fine until you start to upgrade again.
Old 02-13-2007, 04:08 PM
Cantalope Kid's Avatar
Why not just upgrade to SVO 30lb or 40lb so your covered by not going over the 80% duty cylce on the stockers? It will also have you ready for future upgrades...Nitrous or Forced Induction later as well...
