largest cam size -ls6 springs
Old 02-06-2007, 08:07 PM
lexar13's Avatar
Default largest cam size -ls6 springs
i have ls6 springs and want to know what the largest cam size i can go with. wanting to run cam only daily driver with a mean *** idle. i race bikes so i just want some more fun in my grocery getter SS.
Old 02-06-2007, 09:05 PM
HEMIETR's Avatar
Stock springs suck. I would replace them with any cam swap.
Old 02-06-2007, 09:15 PM
kyles2000z's Avatar
hotcam will work with LS6 springs. pretty choppy idle but its a smaller cam and theres not a lot of hp gains from it.
Old 02-06-2007, 09:34 PM
david vericker's Avatar
570 lift with the 2002 -2004 yellow LS6 springs. The springs don't suck - you just need to use them properly.
Old 02-07-2007, 01:50 PM
HEMIETR's Avatar
I won't argue with you. But they do suck for anything much more than a stock cam. For the price of springs it's cheap insurance.
Old 02-07-2007, 02:01 PM
speed_demon24's Avatar
That doesn't mean they have enough spring pressure to control the valves.
Old 02-07-2007, 02:50 PM
I ran the those springs for a full season with the cam that just came out of the car. At that time the Comp Cam made 224/228 563/568 with Ti retainers and 1.80 ratio rockers turning 6600 RPM.. The vette ran 11.95 - 12.05 with no valve train issues whatever. Don't listen to all these bench racers - most of them don't know their *** from a hole in the ground.
Old 02-07-2007, 02:57 PM
Thats a big part of why they worked fine for you.
Old 02-07-2007, 03:00 PM
spazzyfry123's Avatar
I plan on running those springs with GMPP's ASA cam. Specs are...:
226/236 /525"/.525" 110 LSA
It definitely has a mean *** idle, and from various owners of the cam, they all say you'll never have to worry about the springs again (assuming you are running the yellow striped LS6 springs). It doesn't necessarily make the largest numbers, but what I really like about the cam is its under the curve power (~350rwtq @ ~3K RPMs!). Check out a thread I made not too long ago about this cam HERE
This is an idle clip of a member on here's car that has this cam: HERE His screen name is jmm98LS1.
Old 02-07-2007, 03:05 PM
1997bird's Avatar
There is only 6 grams differance between the Ti retainers and the steel retainers. There goes your theory! It depends more on the weight of the valves. Those springs were designed with the hollow stem LS6 valves in mind. Another part to look at is how agressive the lobes are on the cam.
Old 02-07-2007, 03:41 PM
JstALs1's Avatar
You should have no problems i run the blue z06 springs (I dont know if the color makes a difference) On a cam with 581 lift on Int and Ext with no problems for the past three years and i beat the hell out of the car.
Old 02-07-2007, 03:44 PM
JstALs1's Avatar
I love the way that cam sounds 110 rocks a buddy of mine has that cam in this t/a made pretty good numbers too
Old 02-07-2007, 03:55 PM
I do beleive that the blue Z06 springs are the 2001 version. They are supposedly only good for 540 lift, but they sure seem to work good for you.
Old 02-07-2007, 04:10 PM
If you don't mind, could you tell me what numbers he made? I'm trying to gather as much info as I can about the cam. If you have a dyno sheet, that would really help!
Old 02-07-2007, 05:00 PM
JstALs1's Avatar
it was a installed on a 98 6spd car made 360 rwhp and 362 rwtq. Cars only mods were cat back and a K&n filter. Ran a 12.7 at 114 with 4.10s on nittos. Numbers might seem low but keep in mind car had a stock ls1 intake, lid and exhaust manifolds so no to bad in my book. Since then he has done supporting mods like headers, lid, ls1 intake, ported tb and True duals. hasnt had it dynoed since but the car has gone 11.9 at 116 with m/t's until the 10 bolt blew. Hope this helps.
