Anyone know torque specs for arp head studs?
Im putting my heads back on this weekend. Its been a while and i dont remember the sequence and torque specs. They are arp 12 point studs,also the intake specs. Im using cometic .051 gaskets if that matters and a fast intake.
Thanks alot.
Alex
Thanks alot.
Alex
Thanks alot.
Alex
Thanks alot.
Alex
Hammer
25lbs on the 5 top ones, 70 on the larger ones. This of course is when you use ARP moly lube too.
http://www.arp-bolts.com/Catalog/Catalog.html
Scroll down and click on torque specs.
i dont want to hijack your thread bro but can someone shed some light on the ARP Moly Lube???
is it neccessary?
is it neccessary?
is it neccessary?
Hammer
Originally Posted by thehammer69
Brad, I realize that the small bolts themselves generically allow for 25lbs...but the spec in this specific application is 23 ft/lbs. It probably has to do with stress on the aluminum threads in the block.
Hammer
Hammer
Thanks alot.
Alex
Thanks alot.
Alex
Anyone else for torqueing more do to the cometics.
lol, 22, 23, 25 whatever, its really doesnt matter. Where did you get 23 from anyway, cite a reference please. if goiong up to 25 from 23 breaks threads, your block is a POS and fucked up in the first place.
Is the moly lube just used between the nut and washer or washer and head, or on the actual threads? What about ARP head bolts? Is it the same 70/25 numbers and moly lube between the head of the bolt and cylinder head?
With bolts it goes on the bolt threads and face of the bolt head where it contacts the head.
Torque values are in the link that i posted above.
Originally Posted by vettenuts
I was also given 23 lb-ft by ARP tech support.
