Stock head gasket thickness and Bore?
Old 02-11-2007, 08:22 AM
shaulinmathvader's Avatar
Default Stock head gasket thickness and Bore?
I am trying to find out what the stock head gasket thickness would be on a 2000 SS camaro and the bore size on that gasket. Looking to buy gaskets that will take 150 shot on a trex cam. But I might need to mill heads so i need to know what the stock thickness would be so I could mill heads accordingly since I have trex cam. A search yielded nothing. I was told that the smallest bore size gasket would be 3.955? But then the cometic say 3.910 bore.
Old 02-11-2007, 08:53 AM
PREDATOR-Z's Avatar
Are you flycutting?
Old 02-11-2007, 09:23 AM
lmt0705's Avatar
pretty sure the stock mls gm gasket is .052 thick, bore diameter is around 3.950
Old 02-11-2007, 10:20 AM
ArcticZ28's Avatar
Stock bore is 3.905 and thickness is .052-.054 compressed.
Old 02-11-2007, 10:40 AM
brad8266's Avatar
i measured mine after i took it off, it was .050
Old 02-12-2007, 08:23 AM
Ok. No im not flucutting.
So I have to get gasket .052 to .054+ Milling measurement and the bore size for the gasket should be 3.905. I'm I correct
Old 02-12-2007, 08:48 AM
PREDATOR-Z's Avatar
You cannot mill a head on a T-rex without flycutting. Stock gasket.
Old 02-13-2007, 07:56 PM
Would anybody sell lets say a thicker than stock gasket. So I can mill the heads just to resurface them
Old 02-13-2007, 08:26 PM
ArcticZ28's Avatar
That's not an optimal path to go. Go with the .040 cometics, resurface the heads, and flycut accordingly.
Old 02-16-2007, 10:26 PM
Lets say i cannot open the bottom end right now. No flycutting. Is what I want to do the best way to go
Old 02-16-2007, 10:29 PM
brad8266's Avatar
You dont have to tear the bottom end up to flycut, you can do it with just the heads off.
Old 02-16-2007, 10:32 PM
Mr.MartyStone's Avatar
No. Forget the biggest cam is best mindset and pick a cam that will actually work for your application. If you already have the T-rex then swap cams if you want to mill your heads. You can also always get a TFS, ETP, AFR, or Dart head that will increase p-v clearance off the bat, and then work from there.
Otherwise you're just being silly about all of this. Do a search and see that a T-rex is about as close as you can get in stock situations. Anymore and you'll be kissing pistons.
Marty
Old 02-16-2007, 11:33 PM
BOWTIE's Avatar
I agree with those above, if you want to keep that cam, run a .040 gasket, mill about .050 off of the heads and flycut. That is the only way to make that cam work well. According to pianoprodigy's calculator you are between 7.5-7.7 DCR depending on if that cam was ground or installed with any advance. The general concensus is that you want to run around 8.5 or so DCR. This would require a .040 gasket and 60cc head with that cam. If you drop the duration then you can achieve that same DCR without having to increase the SCR as much (less mill) which would decrease the need for flycutting (x2 actually, because less mill= less flycut and less duration= less flycut). So there you have it, either flycut or go with a smaller cam. Lastly, you do not want to increase the gasket thickness to make up for what you mill because the gasket is larger than the cyl head conbustion chamber, so you will be decreasing your compression even more by doing that even if you add the exact amount to the gasket that you mill from the heads.
