Anyone running a trick flow cam?
Old 02-11-2007, 03:46 PM
SSDoubleK's Avatar
Question Anyone running a trick flow cam?
I see these are new out for the LS1, price seems to be fair at 269.95, was wondering if anyone was running one, or what they think about them. THanx DoubleK
Old 02-11-2007, 07:42 PM
seawolf18's Avatar
Im wondering what the specs on those cams?
Old 02-11-2007, 09:23 PM
oange ss's Avatar
i imagine if they're anything like their heads you wont be disappointed...
Old 02-11-2007, 09:38 PM
SSDoubleK's Avatar
Here are the specs on the cams available, they seem to nice. 216/220 560/560,220/224 575/575,228/230 585/585, they do not list the LSA on them. Summit Auto Racing is the only place so far I've found selling them.
Old 02-11-2007, 09:44 PM
Okie5.3's Avatar
TEA sells them also.
GM LS-1
TFS-30602001 216/220 .560/.560 114
TFS-30602002 220/224 .575/.575 112
TFS-30602003 228/230 .585/.585 112
Old 02-12-2007, 08:50 PM
SSDoubleK's Avatar
How much on that website for those cams?
Old 02-13-2007, 12:46 AM
cws T/A's Avatar
https://ls1tech.com/forums/dynamometer-results-comparisons/567919-dyno-proven-tfs-head-cam-combinations.html
Old 02-13-2007, 07:32 AM
SSDoubleK's Avatar
I did a search and this did not come up. Thanx for the info.
Old 02-13-2007, 09:36 AM
JPH
JPH's Avatar
i'm pretty sure crane is grinding these cams. they are very impressive lobes, and they will make the power.
Old 02-13-2007, 04:06 PM
prdtr15's Avatar
they look to be pretty good, ive run there cams in a SBF and it was great
Old 02-13-2007, 11:43 PM
SSDoubleK's Avatar
Thanx again for your input.
Old 02-14-2007, 10:03 AM
LS1TECH Sponsor
Vengeance Racing's Avatar
I have used there Stage III cam to test and they did great for the specs they are.
Old 02-14-2007, 09:38 PM
SSDoubleK's Avatar
Wink
This is great info. Thanx again.
Old 02-16-2007, 10:04 AM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
Crane is not grinding these.
Andrew
Old 02-16-2007, 08:59 PM
SSDoubleK's Avatar
Okay Crane is not grinding these. Who is?
Old 03-12-2007, 08:39 PM
steelers71's Avatar
just wondering if there is anymore info on these cams floating around. I am thinking of trying the Stage 3 with TEA stage 1.5's.
Old 03-15-2007, 10:36 PM
SSDoubleK's Avatar
There is some more info. couple other people ran some threads on these cams, just do a search.
Old 03-15-2007, 11:55 PM
PunkNPonys's Avatar
I noticed in Summit that it says the minimum compression is 10:5:1. Is that true?
Old 03-16-2007, 01:37 AM
ArrestMeRed99Z28's Avatar
I'd like to see them off some more aggressive cams, mostly so I can buy one cheap and use it in my cam only application, but something along the lines of the Vengence Vindicator would be good.
AJ
Old 03-16-2007, 06:53 AM
I am getting ready to install the big cam in my LS6.
Andrew
Quick Reply: Anyone running a trick flow cam?
