Which Red Tube Loctite
Old 02-12-2007, 06:49 AM
cjh
cjh's Avatar
Default Which Red Tube Loctite
On ls1howto it mentions to get loctite red tube, but i found a medium strenght red tube and a heavy duty red tube. Which one? Tried searching but couldn't find specific answer, oh and sorry for the dumb question.
thanks
Old 02-12-2007, 08:32 AM
SScott236's Avatar
I used the heavy duty stuff.
Old 02-12-2007, 11:17 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Same here
Old 02-12-2007, 11:46 AM
ROCNDAV's Avatar
For what application? Where are you using it? Most LocTite thread lockers have a number. The 222 (purple liquid) and 242 (blue liquid) are the most common threadlockers that can still be removed if needed. The two red liquids (262 & 272) are considered "premanent" and will require the use of torch/heat to loosen at a later time (if needed).
Old 02-12-2007, 12:20 PM
HAMRHEAD's Avatar
I've used the heavy duty and medium depending on what it is that I'm using it on.
Old 02-12-2007, 04:48 PM
jermzz's Avatar
YEah man use the 242. The red **** is no joke. Vibration wont break the blue loose. I used it on my crank bolt and flywheel bolts and i'm spinning high R's with no problem.
Old 02-12-2007, 05:09 PM
brad8266's Avatar
red ftw!!!
Old 02-12-2007, 05:29 PM
cjh
cjh's Avatar
I got 242-medium and 271-heavy, going to use it on cam retainer, bolts, etc. Any where ls1howto mentions to use loctite.
