aftermarket rockers - stock rocker stand
Does anyone know of an aftermarket rocker system that maintains the stock rocker stands?
Most of the systems I've seen eliminate this part.
The reason I'd like to keep it is I'd like to use LPE's HD rocker stands to reinforce the top of the heads on my ported heads (they are pretty thin up top).
I could use a Jesel or Comp shaft system (which have there own steel rocker stand), but they're a little pricey - plus the $ of the valve cover spacers or aftermarket valve covers.
Probably gonna end up sending my stockers to HS for the rebuild, but wondering if I have any other options.
Thanks for any input!
rck
rck
