Help With Patriot LS6 stage 2 Heads
Old 02-15-2007, 11:54 PM
tamikews6's Avatar
Default Help With Patriot LS6 stage 2 Heads
I recently bought these heads from ebay and was wondering if It is to much for what I am going for. I will be running a TR224/224 cam/ Fast 90/90 and supporting mods. I am really not to excited about having to buy new rockers. Is there heads similar to these that take the stock rockers? I also do not want to fly cut. If not what are some good cheap rockers to work with these heads?
Here is the discription from ebay:
These heads are fully ported they have rocker studs already installed they were only run for about 1000 miles. They have 59cc chambers and 205cc intake runners. 1.57 exhaust and 2.02 intakes valves the valves are manley stanless valves.they also feature partiot dual valve springs and oversize locks.
Attached Thumbnails Help With Patriot LS6 stage 2 Heads-adb9_1.jpg   Help With Patriot LS6 stage 2 Heads-aff7_1.jpg   Help With Patriot LS6 stage 2 Heads-b329_1.jpg
Old 02-16-2007, 12:58 AM
Long Beach's Avatar
I saw those, they sold for a great price. I would take the extra money that you saved and just buy some rockers to go with it. I think you can just use a stock mls gasket and that should put you arround 11:1. What is the lift on the cam, usually as long as you stay under .610 lift on the exhaust you should not have to fly cut. Good luck
Old 02-16-2007, 02:18 AM
Bader-X's Avatar
did patriot have a 205 cc intake runner version of the ls6 or ls6 style heads? or even the 5.3 or ls1 heads? never read that ....
Old 02-16-2007, 07:57 AM
tamikews6's Avatar
I am looking at some harland but I don't know anything about rockers. Whats the difference between adjustable and not? Are the yella terra any good?
Old 02-16-2007, 09:48 PM
Long Beach's Avatar
Im planning on sending my stock ones in to harland and for 250 they will fix them to make them reliable. If i were going to buy some aftermarket ones it would be jesel or what ever its called because they are good.
Old 02-16-2007, 09:51 PM
HEMIETR's Avatar
Did I miss something? Why won't the stock rockers work?
Old 02-16-2007, 10:54 PM
Long Beach's Avatar
They will work but they have been known to fall apart. Oh you mean on his heads, i think the stock rockers will work on his but im not sure.
