Your Best Setup and CR.. Milling, HGasket, etc
Old 02-17-2007, 03:49 PM
Supajut's Avatar
Default Your Best Setup and CR.. Milling, HGasket, etc
Basically:
How much did you mill your stock heads, or what CC did you mill them to?
What gasket/thickness did you use?
What did your compression ratio end up at?
Any Flycutting or clearance issues? (cam specs please)
And are you happy with the results?
THANKS!
Old 02-17-2007, 03:54 PM
brad8266's Avatar
57cc, .040 gastet, 232/236 .575 .578 112+0 cam, -2cc pistons, 11.79 SCR, 8.6 DCR.
Dont know if i like it since I havent driven it yet, but Im sure it will be sweet.
Old 02-17-2007, 04:00 PM
Supajut's Avatar
Ha! Yeah, I have done alot of research and came across more than one other post of yours on this subject. Thanks for the heads up. Basically just trying to see what everyone has and how they like, then I will use that info toward my setup. Wanna get somewhere around 11:1, prob gonna run Cometic .040 gaskets...... We'll see.
Justin
Old 02-17-2007, 04:22 PM
mr2guru's Avatar
The keys are to get a good quench, factor the cam in your max compression calcs (DCR), and watch your PTV.
Old 02-17-2007, 04:24 PM
Supajut's Avatar
Where would I find the equations to do the math myself?
Old 02-17-2007, 04:51 PM
brad8266's Avatar
there is a compression calculator in this forum, search through the first few pages of this forum.
Old 02-17-2007, 09:38 PM
mr2guru's Avatar
search for pianoprodigy's excel calc.... it works well. Plus it has all the comp lobes .006/.050/.200 numbers used for DCR calcs
Old 02-17-2007, 09:56 PM
Supajut's Avatar
Thanks guys, I'll check it out. Anyone else please post up your combo and let me know how it worked out for you. Thanks, Justin.
Old 02-18-2007, 09:28 AM
slow trap's Avatar
when i was stock bottom end i had 57cc tea 5.3 heads,factory mls gaskets,comp 228r on a 112 +2. made 436 rwhp,402 rwtq. 11:6 - 11:7 scr, 8:9- 9:0 dcr. done awesome on 93 but unfortunately i spun a bearing not long after
