Are 862 5.3 Heads good? - LS1TECH
Thread Tools Search this Thread
Old 02-19-2007, 11:57 AM   #1
camaro98z28's Avatar
Default Are 862 5.3 Heads good?
With my mods listed below, I dynoed 426 RWHP with these TEA 1.5 Heads. The heads were ported and milled a bit. I was wondering if I'm doing ok with these heads? I was also thinking about going to the AFR 205 heads and was wondering what gain I should see.
camaro98z28 is offline   Reply With Quote
Old 02-19-2007, 12:19 PM   #2
slt200mph's Avatar
Good numbers for a automatic car..those 5.3 TEA heads are pretty good..I would not make the change you might not pick up anything..
slt200mph is offline   Reply With Quote
Old 02-19-2007, 02:14 PM   #3
prostock_bigblock's Avatar
Quote:
agree.
prostock_bigblock is offline   Reply With Quote
Old 02-19-2007, 02:21 PM   #4
So going to better head might not make more power?
Old 02-19-2007, 03:08 PM   #5
slt200mph's Avatar
Quote:
It might not be a better head..just because you pay more does not mean it is better. My TEAs flow 316 cfm that is as good as the AFRs. If you were a six speed car you would be in the mid 400s which is pretty good. The only way you are going to pick up any HP is going with a ported 90/90 combo ... the latest and greatest on the aftermarket head scene now days are the $3000 trick flow heads..I would go with the 90/90 first..after you get to the mid 400s adding more HP is pricey compared to the first 100+ HP you gained with your mods ..
PS the L92 heads and intake might be good if you had bigger cubic inches but with a 346 size motor the trick flows are the shinizznit now.. those heads and the 90/90 are bad *** ... Vengeance Racing just did a 346 with the trick flows and it made 524 rwhp.. it was a six speed car and thoes are stout numbers ..
Old 02-21-2007, 07:43 PM   #6
Yeah I was thinking of getting the FAST 90/90 set up. 20 HP more would be great plus look great. I wonder what else I can do to make a few more HP numbers.
Tags
02, 15, 53, 862, flow, good, head, heads, ported, spec, stage, tea, trick
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
