Synthetic Oil Changes
so today i switched to mobil 1 10w30, my sticker says i need to change it in 3K miles, but isnt synthetic 6-7K miles depending on how its looking? I thought it was but i want to double check. Isn't it the oil filter that needs changed every 3K regardless of what oil is used?
Board Certified Idiot
Even tho your Oil in your Car is able to withstand 6k Miles of Use or More..That dose not mean your Oil Will not Get Dirty Before that.. Which is the main Reason why is should BE changed around 3Miles. Expecially if you Drive up and down Dirty Roads Just a Thought
Originally Posted by Sunset'01Z
where are u guys getting this german castrol? i work at napa and my boss laughed at me when i asked him about it lol..
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
well i feel like seals are the big thing. i mean that sounds like an oil change ad but definably change the oil filter every 3k
but I always keep an eye on the oil, checking it every time the hood is open
I use RP and I want to try the XRS RP but haven’t had a chance yet, i feel like a retarded consumer for using regular RP sometimes.
the synthetic oil will last for a long *** time, but the contaminants and abrasives in it will be the reason to change it. which is dependant on environment, i suggest if you run it 8-10k miles, you should change the filter and top it off every 2500-3000 miles just to help it a little. synthetic every 3000 miles is expensive, not that i would cheap out on something like oil, but i run mine atleast 5k. if more the filter was probably changed atleast once already...
Every 3000 miles I change the filter, and top it off (Mobil1). 3rd filter change (9000 miles) I change all the oil, then repeat the process.
The inside of my motor is dayum clean (68000 miles).
Originally Posted by jbutta224
can u guys tell me whats the deal with this german castrol oil
It runs on the thicker side of the 30 weight range instead of the thin side
It produces some very stellar Used oil analysis results.
Hammer
They're all synthetics. The thing with German Castrol is that it is one of the few - if not the only - that begins life as a synthetic oil. In reality, even the class III synthetics are great. Just because they start as a dino oil doesn't mean that they still are after molecular changes.
I agree with the guys saying to change the filter every 3k, since filters aren't designed to go as long as the oils. I like the idea of changing my filter every 3k, and oil every 6k.
hey N4cer, i like that idea with the filter and the oil!! i just cant spend almost close to 70 bucks every 3k miles. i never dog my car or beat it at the track.
