5.3 overbore
Old 02-20-2007, 04:40 PM
inline300's Avatar
Default 5.3 overbore
Lets say I want to purchase a 5.3.
Lets say I want to bore it .120 and drop stock LS1 pistons in it.
Im told this can be done on a 5.3 iron block, can this be done to the 5.3 aluminum block as well, without installing new sleeves?
Thanks
Old 02-20-2007, 05:19 PM
GR33N GoblinM6's Avatar
you wont be able to take the sleeves .120 on an aluminium block.. sorry.. if you need 5.7, get a 5.7 it will be cheaper.
Old 02-20-2007, 05:22 PM
slowride's Avatar
Yes, I believe they are the same block with more bore size on the 5.7. I remember some topics where people started out with a stock 5.3 aluminum block (stock sleeve) so they had room to true it up if needed.
Old 02-20-2007, 05:27 PM
inline300's Avatar
So we have one no and one yes.
Do we have a tie breaker?
Thanks fellas
Old 02-20-2007, 05:28 PM
cablebandit's Avatar
iron block yes...aluminum no idea
Old 02-20-2007, 11:47 PM
from what i have read.. you can not take aluminum sleeves to that... i have read and heard you can have them honed.. but not bored out like you want to..
Old 02-21-2007, 09:25 AM
NO-OPTION-2002's Avatar
Engine Masters had an article within the last 2-3 months were Tony Mamo built a 600+ (crank) hp 383, using a new 5.3L ALUMINUM block bored out to 3.898" with a 4" crank.
So yes, based on that info, I'd say it is very possible.
Old 02-21-2007, 07:57 PM
slowride's Avatar
It was this buildup and Jason(I think) from Thunder Racing's 383 where I noticed something similar. I believe the sleeve has the same outer diameter and is either thicker or bored more for the 5.7L's
