How do YOU go about keeping lifters up?
I know the 3 methods. I havnt done a cam before, but the guys I know who have use the "roulete" method. I would rather keep the lifters up with the wooden dowles, but I cant find the dern dimensions of the rod anywhere! I think it was 23in of 5/16? Do any of yall know if that is correct? Have you done it with the wooden dowles, or is that risky(breaking). Who prefers the magnet technicque?
Any advise or personal experiance would be AWSOME!
thanx.
thanx.
when i ordered the tool from thunder it was on backorder and i wanted my car done asap so i used the magnet trick and it worked to perfection AND i'll never run out of pen magnets around the garage.
Originally Posted by 99blancoSS
I rent out all 3 specialty tools you need. Crane dual spring tool, JPR rods and air fittings for the cylinder. PM me for details
I just got the cam in. Thanks anyway Blanco. But, you wouldnt happen to have a majic "oil pan be loose" tool in there would you?LOL I cant get the damn thing to drop...
What he said , make sure you loosen all the bolts a good amount, it wont fall off, the k-member is in the way or you could just take the pan off and do it right. Its stuck on there but be careful to not pry on the gasket if you try and pry it down. I banged it a few times with a peice of wood, I didnt have a rubber mallet, and pulled it down.
Make sure you get those long *** skiny bolts in the back of the pan
