Heat cycle and retorque ARPs?
Old 02-24-2007, 09:56 AM
The Sad's Avatar
Default Heat cycle and retorque ARPs?
I just finished installing my new heads with ARP bolts. My question is, do I need to heat cycle the car a few times then tear it down and retorque the head bolts, or will it be fine with out?
TIA, Aaron
Old 02-24-2007, 09:59 AM
Viper's Avatar
They claim you should, I did not do it on my new heads and ARP bolts. 6K on the motor now, running fine. For peace of mind it's a good idea.
Old 02-24-2007, 01:30 PM
JPH
JPH's Avatar
TIA, Aaron
it's best to do this, but very few actually do it. only if the engine were on a engine dyno, where it would be a piece of cake. i always let them sit 24hrs, then go back and check the trq. on all of them again.
Old 04-15-2007, 06:10 PM
The Sad's Avatar
FYI - I heat cycled and tore one valve cover off. I tried to retorque those, but 4 were at torque, and one barely moved. I assumed the rest were OK.
Old 04-15-2007, 06:13 PM
brad8266's Avatar
I have studs and didnt bother retorquing after a heat cycle. I did however check the torque a few times when the engine was sitting on the stand over the span of a few days.
What I would do is torque them like 5 ft-lbs over, that way if they lose a little torque after heat cycle they will still be within tolerance. A little extra clamping force wont hurt anything anyway.
Old 04-15-2007, 06:56 PM
DAVESS02's Avatar
I didnt re-torque with felpro 1041's and I wound up blowing gaskets. After installing ICE Titan gaskets the THIRD time, blew the second set too, I re-torqued twice. Both retorques moved the nuts about 1/8 of a turn tighter on ARP 12 point studs and nuts. I'd never skip a retorque no matter what again.
Old 04-15-2007, 06:58 PM
brad8266's Avatar
Like i said over torque them some on initial install and when they lose a little torque you wiull still be OK.
Old 04-15-2007, 07:24 PM
RAACCR's Avatar
I retorqued mine (with Cometics). No problems, but better safe than sorry.
Old 04-15-2007, 10:46 PM
motorbuilt's Avatar
When you retorque, dont just torque them. You need to loosen the nut then retorque one at a time.
Old 04-15-2007, 10:48 PM
motorbuilt's Avatar
Run factory MLS gaskets and you'd be better off.
Old 04-16-2007, 10:54 PM
DAVESS02's Avatar
Factory gaskets dont give the desired quench I wanted and the Titan ICS gaskets have far better sealing capability than the GM gaskets IMO.
Quick Reply: Heat cycle and retorque ARPs?
