intake help please
intake help please
im putting a ls6 intake on my 2000 T.A. and i cant remember which side this bracket goes...the bracket has 2 intake manifold bolts going through it and has a sensor hooked on it and the wire from the sensor runs under the intake...can anyone tell me which side the bracket goes on and if it goes on the front or backside of the intake?
Thanks
Thanks
Originally Posted by 01LS6SS
Might be the black bracket on the back of the drivers side head??? the one that bolts to the back inside of the head with a 15MM bolt and also bolted to the valve cover???
Originally Posted by 408 z28
no, the bracket has a sensor connector on it and the wiring to it runs under the intake to the 2 circle plugs and it is held in place by 2 intake mani bolts...
The bracket mounts on the right back side of the mani when looking at it from the front.
It's the knock sensor bracket.
It goes on the drivers side.
Taken from LS1Howto 3rd to last picture caption.
Originally Posted by LS1howto
Next, re-insert the 4 rear long intake manifold bolts back into the manifold (remember, the drivers side rear of the manifold has a metal bracket that is held in place by the rear 2 bolts on that side) and while holding them up, slide the manifold back into place. Reconnect the rear sensor, as well as the small vacuum line, and snake the big brake booster line back into place and reconnect it.
Originally Posted by brad8266
No I think that is the EVAP sensor on the bracket thingy and it plugs into a different connector not the knock sensor cable, which are the only wires that are under the intake.
