need help starting my build up
i was just wondering if there will be any problem here. most people ive asked said there shouldn't be .
im using a 97 ls1 block, 99 lifter trays, ls7 lifters. will i run into any problems with this setup?
thanks in advance
chris
thanks in advance
chris
Originally Posted by snake charmer
The lifters should work fine as I think they can be used even on a lt1 block .
Just wondering the 97 ls1 block could only be out of a 97 vette as the ls1 did not make it to fbody till 98 .
