LS2 intake on EARLY LS1
Not debating whether it's worth it or not, but I have an LS2 intake (ported the flashing) and TB setup. What is needed to put it on an early (97) LS1. Do I need an LS6 valley cover....what about the TB?? Rewire the harness, or will the larger TB work as-is???
Any How-to's floating around on this??
Thanks!
Thanks!
The stock LS1 fuel rail will not fit on it and you need to either buy the 01+ collant crossover pipes and plugs or grind down the ridges on the belly of the manifold. I would just grind the ridges and save the 50$, thats what i did on my LS6.
I have the LS2 injectors also, and if they have the same plugs, I can easily program the PCM for the LS2 injectors....I should have mentioned this first.
Does anyone make the TB and MAP adapters, or can I just re-wire myself??
Thanks for the quick replies so far
appreciate all of the opinions...may get an LS6 setup... I just have an LS2 intake here, now, and free, but maybe I should put them on ebay.
Thanks!
**btw, it is still hard to believe this setup (LS2 intake and BIG TB) don't flow better than the LS6. The comparison I read said the LS6 setup even flows better than the FAST intake and TB, so I'm reluctant to totally believe it. Like I said above, I did port the flashing clean on the intake, which supposedly helps.
Thanks!
