Some questions regarding TREX.
Old 03-01-2007, 08:13 AM
crazylane's Avatar
Default Some questions regarding TREX.
Well to start off, I have an 02 Z28 A4 with a yank SS3600 stall and stock gears, I have most of the bolt ons, with more to com with the cam swap. I am thinking about the TREX, And I am wondering if there would be any issues running that cam with my current set up. Will I have ptv issues with stock heads, Or even if I get some LS6 heads?
Do you think that would be a good set up for a weekend driver and some strip passes??
Lane
Old 03-01-2007, 08:53 AM
LS1TECH Sponsor
Steve Burger's Avatar
Stock heads will be fine. I think you are light on gear and converter for that cam. It could be a bithch to drive with your setup. Add a 3.90+ gear and a 4K+ converter and it will be fine.
Old 03-01-2007, 09:14 AM
crazylane's Avatar
Well I am not going to go with a different stall cause I just purchased the stall and I am putting it in sat, Is the TRAX Cam pretty good cam? Or a G5X3?
Old 03-01-2007, 10:47 AM
GrimReaper's Avatar
IMO you would be better off with the G5X3. Its a proven performer and would fit your setup better than the TRex
Old 03-01-2007, 10:56 AM
crazylane's Avatar
If I go that route with the G5X3, What should I get it at 111 or 112?
Old 03-01-2007, 11:08 AM
GrimReaper's Avatar
I would give LG a call and have them tell you what the best application for you setup would be, they are really good people out there and very easy to deal with
Old 03-01-2007, 11:39 AM
T'sBlack99Z28's Avatar
the gx3 usally comes on a 112 or 114 and the x4 comes on a 111.
Old 03-01-2007, 11:51 AM
crazylane's Avatar
Thanks for the reply's guys, I just got my pm back from Pred-z, He gave me the info I was looking for.
Lane
