How long will the motor last?
Old 03-01-2007, 08:56 PM
StealthFormula's Avatar
Default How long will the motor last?
I found a very nice '98 Trans Am I would like to buy however it has 132,000 miles, mostly highway The car has been taken real good care of and only mobil 1 synthetic oil used etc etc. Im just skeptical about how much longer the motor will last until it will need to be rebuilt? The car cost $8,000 and is in mint condition except for the high miles so Im just trying to figure out if its worth selling my Formula for.
Old 03-01-2007, 09:05 PM
slowtealz28's Avatar
The way I see it... if the rest of the car is mint (paint, interior, ride quality, tranny, rear, etc.) and the motor just has a lot of miles, I would go for it. With how cheap short and longblocks can be had for nowadays it would probably be worth it. Think about it, for 8k + 5k forged rebuild you have a car that'll be able to run high 11's low 12's on motor, and you could either spray it or go blower/turbo. Or you could just put a 402 or 408 in it and call it a day. I'd go for it man.
Old 03-01-2007, 09:11 PM
Basically I need it to last for another 30k or so until I graduate college in 3 years then I can afford to build the motor up which I would ultimately like to do but Im worried it wont last that long. A 408 sounds pretty nice
Old 03-01-2007, 11:00 PM
GTObsessor's Avatar
If you could do a leakdown test, make sure the thing's runnin smooth (no misses under heavy load), etc. that should give you a good idea. If you only need it to last 30k more miles w/out problems, I'd say go for it. If it's a stick, be ready to spring for a new clutch and make sure that rear end's full of fluid. Check em all actually . Good luck!
Old 03-02-2007, 07:49 AM
01Z0H6's Avatar
I put 223K on my first motor... ( 2000 LS1)
yeah, if it has been taken care of... it will go for awhile..
Old 03-02-2007, 08:56 AM
Has Unresolved Sales
luda0840's Avatar
yeap mine has 165k..still running freaking fast
Old 03-02-2007, 09:03 AM
crazylane's Avatar
Any engine will last a long time, as long as you take care of it, and not Drive like a maniac day in and day out.
Old 03-02-2007, 01:14 PM
BrianMSmith's Avatar
Motor should be fine for 250k with "normal" use. Mine has 105k and runs great, but the clutch went and the rear diff bearings went at ~100k and 95k respectively. This is a fairly low stressed motor overall, the same engine can put out another 100hp without being out of it's design margins. The Ls6 does what, 405hp in standard form?
No worries, enjoy the car.
BTW: my car with 105k miles looks brand new on the interior, though the outside shows 100k miles worth of paint chips. The drivetrain runs perfect. Also had to put new shocks on (strano revalved bilstein HD's).
Amazing car for the money.
Old 03-02-2007, 01:20 PM
LS1Formulation's Avatar
I bought my car with 128K on it, now it has 140K. I did some bolt ons and made the car quicker, and now I am adding more parts to make it even faster. I also can tell you, they last even when beat on. I drive the hell out of my car. It wasn't built to be babied in my opinion. These cars were made to drive hard! *Aside from the weak *** rear end.
Old 03-02-2007, 01:25 PM
SSpdDmon's Avatar
I run into this quite frequently, so I have to ask. How does a car with 130K miles on it attain a rating of mint condition???
That term gets thrown around waaaaaay too much IMO. If it's in great condition for the mileage, that (to me at least) is totally different.
Mint=Dealer Showroom condition (no visible dirt, rust, scratches, chips, dings, stains, wear & tear, etc.)
Old 03-02-2007, 01:29 PM
01ls1lover's Avatar
You can get a way better deal for 8k IMo... Well if your paying cash that is.
Old 03-02-2007, 03:25 PM
bjamick's Avatar
Ya the mileage is fine if proper maintainance has been done. but ya find something cheaper bc 8gs is too much for that mileage.
Old 03-02-2007, 03:31 PM
Yea I was thinking $8,000 was a little high but it does have Chrome ZR1's, Kooks LT's, Magnaflow, LS6 Manifold, Koni SA Shocks and a TCI 3500 Stall which I would put on the car regardless so I suppose $8,000 isnt too bad but I'll try to go lower.
Old 03-02-2007, 04:15 PM
Ryan02SS's Avatar
Perform a compression test and leakdown test if possible and that will give you a really good idea of the condition of the motor.
Old 03-02-2007, 04:20 PM
Cop Car's Avatar
motor will last between 1 and 50,000 more miles.
transmission with a stall... most likely itll go out first. the stall and headers make the car a better deal, but its not like you are getting some super awesome steal. id call it a reasonable deal.
